Hi, I have a whirlpool WFS1071BW 7.5kg front loading washing machine. The "clean pump" red light is coming on and I can't find my mannual to find were the pump is to clean. Can you help me please
    President:
  • 1,554 Answers
The pump is located behind the front bottom access panel. Remove the said panel and you'll see the pump assembly with the pump filter on it. Place a shallow pan or lay a piece of towel under the pump assembly to catch residual water from the pump then turn the filter knob counterclockwise to remove it. Also turn the pump impeller to check for any debris or restriction. Make sure the drain hose is not clogged or kinked. You may need to replace the pump if cleaning the filter, the impeller and the drain hose do not address the flashing of the clean pump indicator or if the impeller is restricted.
Posted on Oct 03, 2010
The red light 'Clean Pump' on my WFS1071BW washing machine is on. How can I access and clean the pump? Thank you for your response.
the small cover trim across the bottom front of the washer comes off. under it is your pump clean out it is a cap you twist off to clean out the pump. have a towel ready water will come out. hope this helps and please rate me thank you...
Jun 06, 2011 | Whirlpool AWM5125/1 Front Load Washer
I have a WFS1071BW and the"clean pump"light keeps coming on. What do I do?
remove the 2 screws by the floor,then remove the cover below the door,there is a clean out cover to remove to let you clean it out,have a pan ready because it will make a mess and a stinky one at that
Oct 14, 2010 | Whirlpool WFW8300SW
My Whirlpool front loader washer has "clean pump" light displayed. How do i clean the pump.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Whirlpool AWOE8748 Front Load Washer
The machine is not draining. the clean pump light comes on
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
Aug 03, 2010 | Whirlpool Washing Machines
Whirlpool WFS1071BW front load washing machine -
Unplug your washing machine and then you will be able to get the door open and the clothes out. You may need to leave it off for awhile to get it to work but make sure you have a bucket ready to catch the water coming out.
May 10, 2010 | Whirlpool Washing Machines
Front loading whirlpool machine WFS1072AW which needs pump clean
WFS1072AW has a clip in panel at the bottom across the front.
Removing this will reveal a black plug on the right.
Unscrew this and water will gush out along with (hopefully) the offending coins.
Feb 13, 2010 | Whirlpool Washing Machines
How do I clean my whirlpool washing machine pump? The red light of my washing machine is on and it is saying clean washing machine pump and my washing machine door won't open.
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It is lighting up on washing machine saying clean pump dont have instruction mannual dont know where pump is
If it is a front load machine you can normaly access the pump from the front sometimes under the kickpanel, There should be a button trap which you can unscrew and clean out the debris. Hope this Helps Kind Regards.
Jul 09, 2009 | Washing Machines
Clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
417 people viewed this question
Top Washing Machines Experts
