Question about Hitachi DV-P323U DVD Player
Hitachi DV-P305U DVD Player .. Will not load dvds. Display says "load" and does not progress from there. ...
5 Suggested Answers
  • 308 Answers
SOURCE: Hitachi DV-PF33U DVD Player / VCR Combo
It sounds like the sensor to tell the microcontroller that the tape is moving is not working. If that is so, the VCR would probably do the same thing in FF or Rewind. If you end up taking this unit into a repair shop, have them check the DVD's software version (it should be 1.250) If below that number, have them upgrade that as well. You can check the version yourself by pressing 1,2,3,4 and then "display" on the remote while the unit is on and no disc in DVD. After noting the version, just hit "power" on the remote to exit this mode.
Posted on Jan 01, 2007
  • 86 Answers
SOURCE: Hitachi DVD player-DV-P325U
If you are using the component output then one of the cables are reversed.
Posted on Feb 11, 2009
SOURCE: Unlock zone Hitachi DVD player
I can't get my hitachi natura to connect to my dvd player using RCA plugs. I can't actually see how to switch to the av mode! Please help - small children going BONKERS!
Posted on Jul 15, 2009
gopakumarg43
  • 75571 Answers
SOURCE: Turned on my Hitachi DVD/VCR combo DV-PF4E}, put in DVD it showed LOADING then it just turned itself off!
Disc loading mechanism fault. Contact any service technician. Loading mechanism should be taken out from the set for repair. If you wish to get more details
http://electronicshelponline.blogspot.com/ Visit this site.
Posted on Jan 07, 2017
When i put a dvd in my hitachi htdk185uk it says unknown disc what does this mean
Either a DVD with the wrong region code has been loaded, and your player doesn't recognise it, or you have inserted a disc which is either rewritable (or an incompatible format for your player), a blank DVD or CD, or the disc has not been finalised in a DVD recorder. It depends on the disc(s) you have, whether they are region coded or those using a compatible playback format (finalised DVD-Rs are the best as far as burned copies go).
Examples of incompatible formats for your player may include;
DVD-ROMs
DVD-RAMs (which are the wrong version/speed for your unit)
Mini-DVDs/CDs
CD-RWs
DVDs with a different region code to your player or rewritable discs
* When using shop-bought DVDs, including those purchased online, make sure their region code matches your player.
May 25, 2011 | Hitachi DV-P315U DVD Player
I need to convert to a region free version for the Hitachi P315U
dvd player will only play movies for the COUNTRY in which you purchased it. There is no way to purchase a system or configure a system to play ALL MEDIA FOR ALL COUNTRIES. The country codes are specific and each country wants to prevent any other country from playing their dvds music, etc
Jan 23, 2011 | Hitachi DV-P315U DVD Player
Will not play dvd
sounds like your trying to play a dvd thats not for the region setting on your dvd player dvds have differnt codes for all countrys what you need is a universal international code for your dvd player (multi reagion) ive tried to look up the code but cant find it sorry try listing for some one to help you if they have the multi region code for your player
Jul 04, 2010 | Hitachi DV-P533U DVD Player
I have a Hitachi DV-DS163A it will play cds but
how long have you been using the player. The problem is from the lens (laser) of your player, its too weak to play DVDs. That is, the power of the lens cannot load DVDs anymore.
The lens still loads Cd's, because Cd's don't have much bytes, compared to that of DVD's. The lens needs to be extra active to be DVD's
Get a lens cleaner and use it to clean the lens, if that does not solve the problem, then its means, the lens needs to be changed completely.
Good luck.
Apr 17, 2010 | Televison & Video
How to reset back to factory setting dv-310. Cant see pic after set to progressive scan
Power off DVD player, hold down Stop (square) button and power back on until display reads Clear. Viola!
Sep 19, 2009 | Pioneer DV-310 DVD Player
How can I unlock Sharp DV-SL2200W
To unlock your DV-SL2200W player follow the below instruction.
1. Switch the player on without disc
2. Using the remote control press "HOME MENU"
3. Select "INITIAL SETTING"
4. Select "OPTION" on screen
5. Press "OSD" button
6. Press buttons, 3,5,7,0
7. The player will automatically shut down
8. Switch the player back on
Now you player will be Multi Region.
Sep 05, 2009 | Sharp DV-SL2200W Player
Apr 13, 2009 | Hitachi DV-P745U DVD Player
Progressive scan, no pictures on tv
Hold down stop button and turn on standby button this will reset to normal mode.
Mar 12, 2009 | Pioneer DV-270-S DVD Player
Hitachi dvd player not reading all dvds
Hello, I'm here try and help your problem, first older DVD players only read certain disc formats, If you have your owners manuel to your DVD player it will tell you what types of discs the DVD player will play. There are seneral types of burnable disc's DVD -, DVD +, DVD-R, DVD+R, DVD-RW, DVD+RW, please looking in the owners manual for the types of discs that the player will read, also in the same secton it will tell the types of formats that it will read DVD Video, DVD ROM, and there is a few others, Next is when you burn DVD's the type of burner you have makes a difference. You will need to find out what format your DVD burn, burns to disc, some of the newer DVD players
read alot of the formats. I would start by finding out what your DVD burns first, then I would suggest buying a DVD player that will read that format. If you have anyother questions please feel free to post them, Thank You and have a great day.
Jan 14, 2009 | Televison & Video
Hitachi DV-P323U DVD Player Logo
87 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
