My philip tft 150s is not adjusting at 1024 by 768 when i m applying this resolution my tft shows, (check cable connection) so pls help me out in this as soon as possible
  • 32,281 Answers
This problem occurs when the correct video driver has not been installed.
Go to Control Panel - Display -Settings tab - Advance - Adapter and if the Adapter type is standard VGA then the video driver was not installed.
Posted on Oct 03, 2010
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
Dell Latitude D620 Laptop Screen Resoltuion Stuck at 800 x 600
That usually means that you have to reinstall the video drivers.
Oct 17, 2008 | Dell Latitude D620 Notebook
What power supply do I hook up tho this monitor
The 12-volt output probably is intended to power a soundbar.
Apr 03, 2014 | Philips 150S1C/74 - TFT/Flat Panel Monitor...
I have a blue screen that says "not support!" i have checked all connections to my television and my direct tv box will not show the screen
It is due to the video resolution feeding the TV is too high for the TV to display, same thing applied to PC monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please ask direct TV on how to adjust the Direct TV box video resolution output.
How is the TV attached to the Direct TV box, HDMI, COMPONENT CABLE, ETC?
Aug 26, 2011 | Dynex DX-LCD37 TV
Hi, I've connected a Philips 42PF9946/79 Plasma TV to a Beyonwiz DP-Lite i Digital Set Top Box. The connection is through a HDMI Cable and TV is viewed on the 'HD' channel/mode. Previous to the Beyonwiz...
@leemcdowall...
your concern points to some adjustments of resolution from your set top box, as we all know all TV'S has fixed resolution doesnt matter what brand and the only way you can change that is through your source which in this set up is your Beyonwiz, please consult their manual and see if you can change the resolution in their video set up page.
Feb 20, 2011 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
My philips lcd monitor 150S is failing me. I switch it on and then it shows and after few seconds the screen is black (meaning its off no picture) Then I off it and on again and then got picture for 2...
Check connections are good. Check pins in plug. Check with another monitor. Check with another cable.
If all tests are satisfactory then replace faulty monitor. End of life!
Jul 13, 2017 | Philips 150S (White) 15" LCD Monitor
50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
I lost power supply for philips 150s LCD monitor
Check with cables2go.com. They sell just about all replacement power supplies and any cables you might ever need. Hope this helps.
Mar 14, 2009 | Computers & Internet
Blurred "No Signal" in the TFT when only power cable is connected.
in display settings try to reset the screen resolution
Oct 16, 2008 | Acer AL2216W LCD Monitor
Computers & Internet Logo
David Payne
David Payne
