Question about Homelite Garden
My homelite f3040 starts but wont run / when i open the choke or increase revs it backfires and or stops . do i need to adjust the idle/throttle screws and if so by how much
  • Homelite Master
  • 7,482 Answers
Check your fuel filter in the fuel tank,if you have one.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Dec 05, 2010
Just fitted a new carb to my gilera runner 50cc and now it revs really high on idle
I would check a few things. First off make sure the throttle cable is adjusted correctly. Second, try opening the throttle half way and letting go you should hear the inside parts of the carb click as they seat. Third, find the idle adjuster screw turn this anti clockwise and see if the idle speed drops down. Fourth check the choke mechanism is working properly choke/cold start forces a rich mixture to the engine and increases the idle revs.
it is worth checking the pilot air screw is adjusted correctly. Hope this helps.
Mar 04, 2015 | Gilera Motorcycles
Carburetor problem?
check the setting for the auto choke and adjust the linkage with it.. Adjusting screw on the throttle butterfly that runs on the fast idle cam of the auto choke.
Feb 18, 2014 | 1985 Nissan Pickup
Backfire carb
Urals need to be throughly warmed up before riding, old technology engine. As far as the revving, I'd Check for vacuum leaks at the Carburator with some carb cleaner while idling, and if that's not it, I'd check the choke.
May 27, 2013 | 2010 Ural Patrol 750
Wont hold an idle revs up and down
Hi, Anonymous and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue please click on the blue links below. Good luck and have a wonderful day.
How To Fix 5 Common Bike Issues RideApart
http://www.thegsresources.com/_forum/showthread.php?181491-Bike-in-idle-and-rpm-s-go-up-and-down-then-stall
Total Motorcycle Forums
You wont get this engine revs by itself
Symptoms of Lean or Rich carb settings on motorcycle
Apr 10, 2017 | Motorcycles
50cc Scooter won't rev up, Keihin PD18J carb
my 50cc scooter will idle at first and rev very well but wont idle what can this be
Jul 08, 2012 | Motorcycles
Need instruction on how to adjust carberator
Adjusting carbs on chainsaws is not to be taken on lightly, there will normally be three screws, an L screw, an H screw, and an idle scre, the L screw will increase the fuel mixture from idle to half throttle ( they are fuel screws not air screws ) the H screw will adjust from half throttle to maximum revs, start with a base setting of between one turn and one and a half turns out, start the saw and warm through, allow it to idle, if need be increase the idle screw to get an idle, turn the L screw in slowley, the revs will increase as the mixture leans off, it will reach a point where it starts to die, now back it off a quarter of a turn, blip the throttle, the saw should pick up clean, if it has a flat spot increase the L screw slightley, now set the idle so it idles without the chain moving on the bar, now screw the H screw in to get full revs, be aware this should be set with an engine rev counter, do not exceed the manufacturersmax revs, hobby saws normally run at about 12500 rpm with an idle speed of 3000 rpm.
Oct 26, 2011 | Garden
Have a 2003 yamaha v star classic 1100. After about 10 miles when stopping at a light the revs go high until the bike comes to a complete stop.After stopping the revs drop to normal.Another thing I noticed...
Hi, Eugene_imric and the usual suspects are:
1. Throttle cables improperly adjusted or pinched.
2. Idle adjusting screw needs to be backed off.
3. Intake system air leak.
4. Fast idle choke ramp is not releasing.
5. Broken throttle return spring.
6. Damaged diaphragm or slide.
7. Faulty MAP, TPS, ATS, O2, VSS sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
high idle when engine is hot
star 1100 high idle untill complete stop
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Sep 17, 2011 | 2003 Yamaha V Star 1100 Classic
83 s-10 2.8 engine needs choked to idle. Open choke
hi if your backfiring your timing is a little out also increase you idle speed on your carb by ajusting your throttle screw hope this helps if you find this useful please rate it thanks
Nov 20, 2009 | 1983 Chevrolet S-10
Briggs & Stratton 135212/0129 - Homelite HL2500
the choke should be in the off position when running. YOU put the choke on to start it then when it starts u turn it off. If the choke is on the engine will die when reving
Aug 02, 2009 | Electrical Supplies
Garden Logo
376 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
