Conceting the red wire in the lecteur autobaby mp3 circuit board
My mp3 player is not working. it cant format.what can i do?
Posted on May 27, 2008
My black and red wires for my nds speaker circuit boards was severed. Can they still be used or do I need a new circuit board?
If the board (PCB) is not damaged you can re-solder the wires back. If the PCB is damaged you should be able to get new ones by looking up the make and model of the device and look for the specific part.
Aug 07, 2015 | Nintendo DS Video Game Consoles & Games
HOW CAN I TELL WHICH RED WIRE IS RC AND WHICH IS RH? THE WIRES COMING FROM MY WALL ARE NOT LABELED AND ARE THE COLORS 2 WHITES 2 REDS AND 1BLUE
This is a fairly hard question to answer. Evidently someone has run two sets of wires to your thermostat. One set has three wires in it: red, blue and white. The other set has two wires in it: red and white. One or maybe both red wires is the rc and rh wire. RC and RH actually wire together with a jumper wire. The RC and RH wire is usually the red wire that goes to the "R" on you furnace circuit board. If you can find out which red wire goes to "R" on your furnace circuit board you will solve the problem.
May 10, 2011 | Heating & Cooling
Wires came loose of control unit from circuit board do you know what order they should be soldered back Green, white and yellow wires are still connected but I don't know where/which terminal to...
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Mar 27, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Avanti EWC-12 circuit board replacement (correction)
the green an yellow wire is a ground. Look for an area on the board with a ground symbol earth.gif. Can you not match the location from the old board???
Either way the black and red are your positive and negative power, while the third is the ground. The wire probably are located in close proximity to each other.
Let me know if this helps
Jer
Jan 16, 2010 | Avanti EWC-12 Wine Cooler
I just changed the battery on a garmin ique 3600 and the backlight won't come on. Any tips?
Most likely you broke one or both wire from the backlight to the circuit board. Open the unit up and look for a black and red wire. Both should be soldered to the circuit board. LED's are used for the backlight and so it does make a different that the back and red wire are soldered to the circuit board correctly.
Oct 04, 2009 | Garmin iQue 3600 GPS Receiver
Je ne suis pas capable d aller dans mon mp3 il ne le reconnais pas et il a une erreur allors je ne peux pas mettre ou enlever des chanson
réinstalle le firmware du mp3 et cela devrait régler le problème
tu devrais trouver le firmware sur le site du fabricant du mp3
dans la section support.
une fois téléchargé, connect ton mp3 et ouvre le ''firmware updater''
il devrait trouver le mp3 par lui meme sinon aide le à trouver le bon lecteur soit le lecteur E: ou peu importe
une fois que cela sera fait déconnect le mp3 de l'ordinateur de facon sécuritaire a l'aide de l'option retirer un périphérique
et ton mp3 devrait maintenant te permettre d'ajouter ou de suprimer des chanssons
Bonne chance
Jun 19, 2009 | RCA JET S2002 MP3 Player
Ac unit central
Sorry, we don't have water cois in our area.
Aug 07, 2008 | Goodman CLQ36AR49 Air Conditioner
My files wont play
Spiralfrog uses microsoft plays for sure drm protection.
Spiralfrog downloads will play on these mp3 players.
When your player is not supported you should find another
download site as drm sucks big time :)
Jan 12, 2008 | Audio Players & Recorders
43 people viewed this question
 Grubhead
Grubhead
