Question about Ovens
Oven keeps losing electronic signal. Get error message E6 F2, then lose all visual digital readout and oven will not heat up.
  • 1 more comment
  • glowie26 Oct 12, 2010
    Okay, now I replaced the board and the buttons are not communicating w/ the board. I cannot change the clock or turn the oven on. Eventually I get an E1 F2 error message again and must power down the oven.
    Thank you for the initial response. I have now attempted to replace the ERC twice. The buttons are not communicating w/ the ERC. Do I need to replace the button panel now as well?
  • glowie26 Oct 13, 2010
    Problem is E1 F2, not E6 F2. I have replaced the ERC twice. Still not getting buttons to function. There is a thin, 1.5 inch electrical strip that plugs into the ERC from the button panel. Could this be the actual problem?
  • 84 Answers
This code error signifies a problem with the control board. It can be repaired at a fraction the cost of buying new. www.fixyourboard.com
Posted on Oct 11, 2010
    Genius:
  • 1,416 Answers
This error code on a Kitchen Aid range indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-yourselfer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
If you have any questions about this repair, please post back with you complete model number, so that I may bre able to provide you with better assistance. I hop this information helps you.
thanks and thanks for visiting this site.
Posted on Oct 03, 2010
  • Anonymous Oct 03, 2010
    hello,
    This
    searspartsdirect.com pcappliancerepair.comappliancepartspros.com
    the average do-it-your self offer. If you decide to order the part and wish
    the board.
    Please rate this solution
    Thank you and thanks for using fixya.
I keep getting the following error message: E6 F2 - what does this mean?
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
I hope this helps.
Dec 12, 2011 | Whirlpool Ovens
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
I have a whirlpool oven which has an error code flashing "E6 F2" the display is coming and going
F2 is most likely the oven temperature sensor. I cant find any reference for E6
Sep 15, 2010 | Ovens
I have a Whirlpool model RBD275PDB12. I am
Hello,the error E6 and F2 you are receiving could be describe as "Cancel Key line open".Follow the following steps
1. Check keypad connector for firm connection(Keypad connection to control board).
2. Press CANCEL if error code returns after 60 seconds,replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replay control board (also called ERC or clock).
TThanks
Jun 03, 2010 | Whirlpool RBD275PD Electric Double Oven
Whirlpool double ovens error message e6 f2
good day,
hope this link below will solve your problem.
ovens
Mar 26, 2010 | Whirlpool RBD245PDS Electric Double Oven
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
81 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
