I attached a new modem to my system today. Now, if I run my system through my router I cannot connect to the internet.The cable people says my computer is running on the router ip address and thus I cannot access the internet. How do I fix this and still run my system through the router? Thanks in advance.
    Problem Solver:
  • 10 Answers
This can be complicated...eveything in your system has an IP address including the router itself. Try using your old router..if it works, then you have an IP adress issue with the new router. Also,
the routers use a scheme called the 802.11 IEEE standard. There are variations on this called 802.11a,b,g,n,etc. Not all devices will work with a 802.11n system...it is still to new. Try using the 802.11g
instead...also most routers use a system called dynamic IP addressing. This means the router automatically signs an IP address to everyuthing in your system...this can change with the addition or deletion of any device in your system...Jeff
Posted on Oct 03, 2010
Belkin F5D7234-4 V5 MODEM LIGHT AND INTERNET LIGHT ARE BLANK. WHEN I RUN A CABLE FROM MY MODEM TOMY COMPUTER, INTERNET WORKS, BUT WHEN I CONNECT THE CABLE FROM THE MOEM TO THE BELKIN WIRELESS ROUTER, NO...
Is this a new router - or should I say did you only have the one computer hooked to the modem until now? Some ISPs use the MAC address of the installed PC to assign the network IP address. Since the Router will have a different MAC address, the modem will not recognize it. ISPs use this as security, but it makes networking impossible. However, most routers have a feature called MAC spoofing, which allows the Router to fake the modem into believing it is the computer originally attached to the modem. On newer routers this is a feature that can be automatically done during the setup wizard. You need to have the original PC hooked to one of the router ports (not WAN or INTERNET) and when the router asks you if you want to use the MAC spoof, say yes.
Oct 23, 2013 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Desktop will not connect to internet when router is connected unplug and go through modem will connect linksys program that came with router will not recognize the router when you setup, worked for over 2...
Each network adapter (in the Linksys router, or in your computer) has a unique 12-character code. Some ISPs (Internet Service Providers) will require you to "register" this 'MAC' (Media Acquisition Control) address, before they grant an IP-address to the device (router or computer). So, when you "bypass" the router, you're showing a different MAC-address to the ISP, and they are not allowing that MAC-address to get connected. Talk to your ISP.
Or, some cable-modems check the MAC-address, allowing just one or two computers to connect. Turn the cable-modem off, to make it "forget" the MAC-addresses that have connected to it.
Connect the router to the cable-modem.
Turn the modem on.
Turn the router on.
Connect your computer to the router.
Restart your computer.
Or, maybe the router really is "dead'; try the above, before choosing this option, and before buying a new router.
Jul 21, 2010 | Linksys Wireless-G WRT54GS Router...
Changed from AT&T to a cable company for DSL. Trying to set up
You need to "fool" your cable box into thinking that the wireless router is the computer. This just means that the modem is locking into the first ip address it can get... it tends to block out all others. Here's how to remedy and allow everything to get access...
1 Shut off computers, routers, everything.
2. Turn on your wireless router FIRST... leave everything else off until you see it's completely booted.
3. Then with the cable connected to the modem/cable box and the router, turn on the cable box/modem and let it cycle up. This should allow the cable modem to "find" the wifi ip address as the main ip.
After that, turn on any other routers, and the computers...
This should allow you access to the net by any of your computers because the wifi router should give all the other comptuers and routers on the system inddividual ip addresses and all should be well...
Give it a try and let me know!
K
Aug 28, 2009 | 2wire (1000-400108-001) Router
I don't know how to connect my router. please help
If you have DSL or cable internet, disconnect the ethernet cable going from the DSL or cable internet modem to the computer. Disconnect the end of that cable that plugs into the modem. Connect an ethernet cable from your cable or DSL modem to the router where it says something like "modem", "internet", or "in". If the router is a wired router, connect the ethernet cable that is still attached to the computer to any open ethernet port on the router.
Jul 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
Wireless router isn't getting internet connection
I am running DSL, but I am sure the method would be the same. The BNC connection (cable) should first enter the cable modem, then ethernet from the modem to the wireless router.
Jun 12, 2009 | Linksys Wireless-G Broadband Router
Router wont work with new modem
Hello Ladoof,
We offer support for Comcast supported routers because they are widely used in the world today. If you are using one such router and it has stopped working, then you just need to call us for instant support.
Comcast Tech Support Internet Help Toll Free 1855 856 2653
May 08, 2009 | Blitzz Technology Computers & Internet
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Connecting to internet
Ok, cable (coax) comes in from wall and attaches to modem. Ethernet cable goes from modem to WAN Port of router. You may have to reboot both devices to ensure that your modem (internet service provider) assigns IP address to your router. If PC is close enough, attach new ethernet cable from one of the 4 ports on your router down to your PC's ethernet adapter. (where your modem used to plug into). Router will now assign an IP address to your PC and you should be able to access the www.
Good Luck and let me know if you have any more questions.
Jul 13, 2008 | Linksys Wireless-G Broadband Router
Unpluging the router
Beings as you're on cable, that makes things easier, and doesn't require any type of configuration.
When you have the router attached to the cable modem, upon powering up the modem, it will register the router's MAC address, not the PC's attached to it.
I have experienced this many times with people who didn't cycle the modem off and on when adding a router, or taking one out of the system - making the hardware appear 'attached' but giving the PC's 'limited or no connectivity'.
Simply unplug the routers power cord for a few minutes and power off the PC.
Plug the network cable directly into the modem from the PC in question. (don't use the USB connection).
Plug the modems power cord back in. Wait until all of the lights are on.
Power up the PC.
This may take anywhere from a few seconds to over a minute for the modem to reinitialize with the new MAC address, but normally happens pretty fast.
Depending on the modem, you may have to do this in reverse order - meaning powering up the PC first, then powering up the modem. In either case, try to avoid using the USB connection - they usually require USB drivers, and tend to be quirky.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
