Question about Pioneer DEH-P3900MP CD Player
Player will not turn on
I have grounded the unit, and there is power going to it. Unfortunately, it will not turn on. please help!
  • 38 Answers
Power needs to be fed to 3 wires:
Yellow ; memory and main supply feed
Red: Accesories supply (comes in via ignition switch)
Black: Ground.
Did you forget either the yellow or red?
Jango
Posted on May 27, 2008
I am installing a Pyle PLDN74BTi double din in a friends trailblazer. I have all of the wires connected to the colors that match and am getting no power to the unit. Please help.
Is the power wire (probably the largest, red) electrically "hot"? There may be a fuse somewhere that you need to install or replace. Is the ground (probably the second-largest, black) well grounded? Without both, the unit will never power up.
Aug 04, 2014 | Car Audio & Video
I have recent bought a fiat punto 2000 model and it had an old standard tape deck in it so i have decided to change it for a cd player the couple i have tryed just dont seem to have any power going to them...
Putting a CD player into a car is not as easy as some people think. The first piece of advice I give to people is to contact Crutchfield and get the proper help- adapter cables and instructions to do the job before plunging into the blind. I have installed many car units and serviced them too for a number of years. There are harnesses to be had depending on the unit you are using and you need to know where all those wires go and when you can't just hook them up any old way. Some cars have common grounded speakers through the chassis- most car amps do not like this at all they need two wires going to each speaker isolated from the cars ground system.
Dec 14, 2012 | Audio Players & Recorders
Vm9424 unit will not power on pressed reset button and it beeps and lights around function buttons come on and go back off fan comes on for about 10 seconds and turns off checked power ground fuses.is...
Hello lumberjack623,
When the jensen starts acting this way, it is simply a power problem. The device is not receiving power from the main source. The battery is weak and need to be charged before the unit can turn on once again. The battery power is too low to turn the unit on.
Try to check the power source or the connection to the power source. It is not charging the players battery. You need to have the connection port replaced. Also the power connection needs be checked.
The battery is simply weak that is why it goes right off when it comes on.
Hope this was helpful to you. All the best Elect_Comp
Sep 06, 2011 | Jensen VM9424 Car Video Player
Pleace help ! with bypassing brake ..on a sdn7ud in dash tv
Unfortunately, I cannot find a good manual on this unit so I am having trouble determining what the wire color is for the brake wire. Usually these units need to see a constant ground in order to work. You can try hooking that wire up to your ground wire, not advisable though. You could try hooking it up to a switch. You more than likely would have to us a certain combination in order to get it to work like flipping it on and off a couple of times, but still is effective. You would have to consult the manuals to find out if there is a combination or not. The other, and most effective, way to make it work is by using a relay. You would just wire up power, ground, and the brake wire to the relay.
Apr 23, 2011 | Lanzar SDN7UD Car Video Player
Will not turn on after hitting the ground
Unfortunately, you likely broke the connection for the power switch- you can try taking it apart and trying to reconnect it- but I do not recommend this
Jan 17, 2011 | Toymax Impecca MP-1825 MP3 Player
How do i fix the mount error, please power off.... on a tascam dp-02 when i turn it on?
The only solution I know of is: turning off the unit, then simultaneously pressing Track Edit, Cursor up, and power button until the unit asks "are you sure?" This will unfortunately erase the hard drive.
Jun 29, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Kenwood head unit not powering up help please.
find your remote wire. it would help to know the type of car and the kind colors of wires your using as your 3 main wires.
normally in most chevy and fords they are yellow 12 volt.
black as ground.
red sometimes even a tan as your remote start.
deff check your start
May 09, 2009 | Kenwood KDC-W6027 CD Player
Jvc kd-sc500 cd car stereo
CHECK TO SEE THAT THE BLACK WIRE IS AT A CLEAN GROUND.....AND YELLOW AND RED ARE POWER..
Jul 21, 2008 | JVC KD-SC500 CD Player
TView headrest dvd player
hi hallow then their is a problem in passing power supply or receiving power supply r some where the connection may lost which unknown to u so please refer it once again and see the battery connected perfectly are not. u explained u r problem very well but such problem can solve by cheaking the instrument practicaly so if still u r problem is not solved its better to consult the expert near to u directly
Feb 24, 2008 | Car Audio & Video
Creative Zen M
Did you charge the unit over night? When they are brand new, the batteries are not always charged. See if the lights and screen come on when it is plugged into the charger. If so let it charge over night and try turning it on again. Otherwise, you should probably return the unit.
Oct 02, 2007 | Creative Labs ZEN Vision:M Digital Media...
Pioneer DEH-P3900MP CD Player Logo
94 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
