Question about D-Link Computers & Internet
D-Link DWM-652 3.5G ExpressCard. problem install
How to solve dwm-156 dial up failed
It's most likely because 'Telephony' is turned off in your PC. Just search Google for Error 711, you'll find Microsoft's solution foir error 711. Just do as directed. USM modem will dial in no time!
Jan 31, 2014 | D-Link DWM-156 3.75G HSUPA USB Adaptor
Tip
How to Install a ExpressCards into your laptop
When we enjoy a weekedn with our family and shoot many pictures. We want to store it in our laptop battery and share with any other friends with email. We use the ExpressCard to connect the camera memory card with the laptop. Also ExpressCard plug-in hardware available includes TV tuners, mobile broadband cards, FireWire 800 (1394B), Serial ATA external disk drives, solid-state drives, wireless network interface cards, TV tuner card common access card (CAC) reader and soundcards. Media remote control units are available that use the ExpressCard slot to store and recharge battery4.us. So we must at least know how to remove and install a ExpressCards.
How to remove an ExpressCard or Blank
Inface removing an ExpressCard is a very easy thing. You can complete it only by two steps:
1.Press the card or blank to remove it from its slot.
2.Save a blank to use when no ExpressCard is installed in a slot. Blanks protect unused slots from dust and other particles.
How to install an ExpressCard or Blank
You can install Express Card while the computer is running. The computer automatically recognizes the card.
ExpressCards are generally marked with a symbol (like a triangle or arrow) or specify a label, which end in the slot to connect. The cards are keyed to prevent incorrect insertion. If the map orientation is unclear, consult the documentation that came with the card.
To install an ExpressCard:
Keep the card shows the top of the card facing up.
Insert the card into the slot until the card is fully engaged in the port.
If you encounter too much resistance, no force. Check the card orientation and try again.
The computer recognizes the ExpressCard and automatically loads the appropriate device driver. If the setup program tells you to load the drivers from the manufacturer to use the media that came with the Express card.
on Aug 03, 2010 | Computers & Internet
Airtel sim not working
It could be that the SIM is not functioning. Try it in a phone. If it works then the DWM is at fault, else ask Airtel to replace the SIM.
Oct 23, 2013 | D-Link Computers & Internet
Tv tuner option
If are talking about the Express Card slot into which the ExpressCard TVTuners are installed, it should be located on the Left side of the Notebook.
Please go through page number 18 of 266 in the Manual of the Notebook which is available through the link below which shows you the exact location of the Slot :
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
By the way, HP no more sells the ExpressCard TV Tuner Cards in HP Shopping.
Only USB TV Tuner Cards are available from HP.
However, you should be able to find Express Card TV Tuner Cards from other Manufacturers.
Hope this helps...
Mar 06, 2009 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
83 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
