Question about Troy Garden
My troy bilt runs for a while and then shutoff, if I prime it again it will start and run for a couple minutes an then shut off. I remove the airfilter it was dirty. I primed it again and started and it ran a while and then shutoff again
  • Troy Master
  • 7,482 Answers
Check your fuel filter if you have one.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
My Troy Bilt model number TB 525 es will start run for a couple minutes then starts stalling why
If it stalls while accelerating, then turn your low side adjustment out a 1/4 to 1/2 turn and try again.
Feb 24, 2015 | Troy Garden
How does the govener and carb linkage work on a Troy-Bilt 2005 800 Series (839) self propelled mower
Have you changed springs? Likely the correct components are there unless you have changed it. Does it run properly and at correct rpm when not in tall grass? Check for proper throttle adjustment first. also check for obstructions (packed grass for instance) under the deck that could be impeding the blade. Lastly, if you have the discharge blocked with a mulch plug, remove the plug. let the tall grass discharge. then run over it again and mulch it.
May 29, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt bronco
Check flywheel alignment key for partial shearing causing a slight out of time situation. .
May 27, 2014 | Troy bilt Super Bronco Tiller 208cc
Chipper/ Shredder runs for while on the amount you primed the eng
Check to be sure there isn't a small hole or crack in the priming bulb. If there is it allows air to enter fuel line, loosing the prime. Most have a collar that unscrews to remove it.
Jul 18, 2010 | Troy Bilt 24b - 060f766 5hp Chipper...
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do you prime a troy bilt 675 pressure washer
if you dont see a primer bulb then you must start it in choke mode after running out of fuel
May 31, 2010 | Garden
I have a troy built self propelled mower, it ran great last season, now it will not stay running. I checked to see if it was getting fuel and it is. I primed it and it acts like it is going to run and then...
The jets in carbs are really small and clog easily. If you stored your mower with gas in it start by replacing the gas. Remove the air filter and prime the carb. Start the engine and place your fingers over the air intake on the carb. This will cause the engine to stall as it will be starved for air. It will also create a powerful suction on the jets and possibly dislodge a blockage. Prime the engine again and start. If does not continue to run, repeat the steps again. If after 3-4 tries your engine wont run you will have to remove the carb and clean the jets manually. The reason your engine runs for a short time is because it is burning the fuel that you put in there by priming it. After that the fuel comes through the jets in the carb and if these jets are clogged the engine will die.
Jun 06, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Garden Logo
63 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
