Question about RCA P52940 52" Rear Projection Television
Projection RCA P52940
Convergence of the red blue and green guns are off in all 4 corners of screen by approximately 3 inches. Center of screen is okay. Bottom and top of screen is arched towards center.
  • 1 more comment
  • wahna May 27, 2008
    which one is the convergence power supply board?? and which one is the convergence board??
  • Anonymous Mar 31, 2009
    the picture is arched and color haloed the adjust proction feature is gone fom the menu on rca p52940 projection tv
    the pictuire is arched and all 3 colors are haloed on the screen along with the white on printing on the screen menu the adjust projectin feature is gone. on rca tv p52940
  • RCA Master
  • 8,617 Answers
Sounds like it is most likely the convergence power supply board, if it were just one color It would most likely be the convergence board itself
Posted on May 27, 2008
  • Sonny Berry
    Sonny Berry May 27, 2008
    the convergence board has about 12 transistors mounted on heat sinks all next to each other the convergence power supply is the other board.
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Curved picture top an bottom
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 04, 2009 | Samsung HCN4727W 47" Rear Projection...
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Blue Projection Gun
It is not the gun ,but the convergence IC that needs replaced providing that you have went into the tv menu and selected convergence and manually adjusted the blue convergence.
Sincerely the Hammerman
May 14, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Convergence problem, lower left corner fixed green gun convergence bows upward
You have a componet out of tolerance in the green drive circuits, resistor or capacitor. If you have the service manual you should be able to take some raedings off the test points for the circuit and be able to track it down. I am enclosing a link where you can purchase the service manual for that set for 10.99. They will mail it to you unless you go back to the site and request that they email it to you by clicking on the contact us link. They also offer unlimited free support if you purchase your manual. I am one of their support techs. Hope this helps. Heres the link
http://servicemanuals.vstore.ca/
Dec 27, 2006 | Pioneer PRO-119 60" Rear Projection...
RCA P52940 52" Rear Projection Television Logo
213 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
