Lg ht 522 th dvd player . keeps saying "no disc "
5 Suggested Answers
sserpentio
  • 88 Answers
SOURCE: lg da3520 home cinema system
you have probably to clean up your dvd player with a clean up CD. After that if your dvd player doesn't want to read a dvd but play a cd, your laser output must be to fix. you'll have to go to a specialist.
Posted on Apr 23, 2008
SOURCE: Hi. Have had an LG
Hi. Have had an LG rc299 DVD/VCR player for 6months now and all of a sudden it wont read any dvd's, burn't or original. Keep getting msg "no disc".
Only thing i can think of doing is putting a cleaner disc into it. Why do things just stop!!!!!!
Posted on Jul 19, 2008
  • 3 Answers
SOURCE: ge 1101 pa dvd player keeps saying no disc
Try turning the disc over.
Posted on Dec 25, 2008
SOURCE: insignia portable player NS-8PDVDA not working
Here's how I've solved same symptoms with our NS -PDVD8a:
1. Cleaned laser optics with isopropyl alcohol/swap --make sure you let the optics dry/IPA evaporate from the optics before running
2. Using compressed air can--cleaned laser track
3. Gently move laser along track several times - it seems laser is having most trouble at start of disc -- not sure it needs lubrication, but running it along track several times seems to have righted it
Had to do this a couple of times, but it's working now -- expect I will need to do this again -- no idea how long fix will work.
Posted on Feb 14, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: my rca drc277 dvd player keeps saying "no disc" when disc is in.
clean laser or replace it
Posted on Aug 27, 2009
How to eject a DVD disc stock inside of Samsung blue ray DVD player does not have DVD tray
There are many reasons for this fault. Visit the site linked below for more information. Type in the brand name of the device in the search box at the top of the display window to get gathered all the related posts. http://electronicshelponline.blogspot.com/
Jan 08, 2017 | Samsung Televison & Video
The DVD player on my Bush 32inch television takes in DVD's but just displays 'No Disc' the model number is DLED32165HDDVD Is it something I can fix?
The player has failed, these types of devices are not fixed as the cost to repair is in some cases more than a new one. More than likely you could not get parts for it even if you knew the cause, which is most likely a failed laser light
Jan 06, 2017 | Bush Televison & Video
Our new blurry player bpm25 will not play disc . It just churns and churns then says chech disc and door opens
Either the laser is faulty/dirty or the spindle motor which drives the disc is faulty.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 06, 2017 | Televison & Video
LG blu ray player has stopped reading discs ..says "connecting" then nothing after that
Try factory resetting the unit
Jan 05, 2017 | LG Televison & Video
I have a Toshiba DVD recorder and I keep getting error code E3 28031100 and a window that says the disc cannot be recorded on. Discs are new or in good shape but, won't play/record. Any solution?
SOME DISCS HAVE SAFETY FEATURE WHERE IT WILL NOT ALLOW YOU TO RECORD IT AND ITS JUST NOT POSSIBLE ON NEWER DVDS BECAUSE OF THE WHOLE PIRACY CASE
Nov 27, 2016 | Toshiba Televison & Video
Need instructions for bdp-bx18 blu ray player.
There is a link to the operating instructions on the Sony eSupport web page found here.
Blu ray Disc DVD Player
Jan 03, 2015 | Televison & Video
My factory DVD player will except disc the ejects it
If I understand your rather cryptic post correctly...
This very well could be a Blue-Ray disk loaded into a
non-Blue-Ray capable DVD player. Your car player's capabilities MUST match the disc, otherwise, the disc won't play.
I've run into this very same problem with my home DVD players. Which both are non-Blue-Ray capable, but I was able to verify the Blue-Ray discs on my PC.
Jan 02, 2015 | Televison & Video
DVD player wont eject dicks or play just say's disc error
You need to insert dicks into the DVD player, also, once it ejects the dicks, you should wait 20 minutes or so before attempting to eject more dicks.
Jun 26, 2012 | Televison & Video
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Electro Med Services...
