Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Replace control board on bosch dishwasher shu53
5 Suggested Answers
  • 236 Answers
SOURCE: Dishwasher Bosch shu 5300
best check the heater at source. the heater relay may have gone internally on the pcb.
Posted on Feb 16, 2008
textonor
  • 130 Answers
SOURCE: Bosch dishwasher
1st pull the 6 screws holding on the outer door panel. Then the 4 screws you already did. Look now at the side of the inner door at the top and you will see 1 screw on each side. Remove these and the panel will fall off.
Posted on Mar 16, 2008
daddy1264
  • 76 Answers
SOURCE: How do I replace the heating element for a Bosch SHU53 dishwasher
are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
Posted on Dec 30, 2008
  • 98 Answers
SOURCE: water in tray on bottom of dishwasher
There is a recall on the control board of many of these models, but your problem is likely not related. I have written a guide to help. It is here. Thanks!
Posted on Jul 19, 2009
Is there a Reset button for Bosch shu53 dishwasher?
Press and hold Scrub Wash and Delicate/Econo buttons at the same time for three seconds. This will advance the unit to "CL" (clean), meaning the washing cycle is finished, and will drain the water. Do this if your unit gets stuck on 1 minute left, which is common with this model. (I am told that the control panel melts over time, and that the unit is not designed to last more than 10 years.)
Jun 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
Need reset sequence
o reset the control module AP2802870, you will put the dishwasher into the cancel/drain mode and let it complete the cycle. When you installed the new control remove the jumper from the original front lower right hand # 1 board male port. Starting from the extreme lower rt.corner, there is a 6-terminal connector with a jumper wire looping # 5 and # 6 terminals. (counting from the right to the left). Use this on your new board. Then reset the controls.
Apr 18, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
My Bosch diswasher SHU5312UC runs down to one min and won't pump the water in or out.
hi,theres a overflow swich it the pan under the dishwasher...it might be sticking or your control board behind the disply for 1 min..is bad...call i will fun you through it...
May 12, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Washing cycle wont complete
I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
Dec 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
My SHU53 only starts on 2Hr Delay and water is not getting hot
Bosch dishwashers run the heating element directly from the control module, which usually causes the solder joint to go bad.....solution, replace the control module, or take the old one out, and repair solder joint
Dec 27, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher Problem
if you remove the front panel (the 6 torx screws) and the facia panel you can access the control module. remove the module and open it up to see if you have a burn mark from the solder melting. if you do then you know to replace the control module
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Nov 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher
check inside the back of the gauge it may have falty wiring or it might just be dirty.
Jun 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
232 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
