Question about Sony KP-53XBR200 53" Rear Projection Television
SONY REAR PROJECTOR TV
I HAVE A SONY KP-53XBR200 AND THE TV TURNS ON BUT CONSANTLY BLINKS THE TIMER/STAND BY BLINKS 5 TIMES A SMALL PAUSE AND REPEATS AND THE PICTURE KEEPS BLINKING, SOMETIMES THE PICTURE WILL NOT BLINK FOR A WHILE BUT THEN STARTS AGAIN. WHAT CAN I DO PLEASE HELP ITS DRIVING ME NUTS!!!
  • 3 more comments
  • mmanzo Jul 15, 2008
    My Sony Videoscope XBR model #kp-53xbr200, turns on, but then the timer/standby light flashes 5 times then pauses and flashes 5 times...etc.
    The screen goes black but still has audio, and it flashes on and off at random times?
    I've seen some of your tips for this, but have no idea what a AKB is or what a screen adjustment is? Please Help!!!
  • bklynwen Jul 24, 2008
    My SONY KP-53XBR200's standby light blinks 5 times, the screen goes blank, then the picture returns. Sound is good throughout. What is an AKB and the screen adjustments?
  • SHRNMCNTYR Mar 29, 2009
    SONY REAR PROJECTION TV 53 INCH TIMER STAND BY KEEPS BLINKING AND SCREEN GOES BLANK THEN COMES BACK ON, PLEASE HELP WHAT CAUSES THIS AND WHAT CAN I DO THANKS ANY SUGGESTION'S WILL HELP
  • Anonymous Apr 23, 2009
    blinks 5 times but i dont no whats wrong with it...??
  • Anonymous Mar 29, 2014
    I have a Sony Tru Surround Tv, it turns off/on 30 seconds at a time into standby /timer mode. Picture and sound is fine,..it just keeps turning off. Any suggestions on how to repairs this ?
  • Sony Master
  • 8,617 Answers
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
Posted on May 27, 2008
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Sony kp53xbr200
You will need technical experience to fix. First what do you remember happening to set before it went out? Did you have color problems, or alignment problems? There are many things that could be wrong. Open startup resistors, R600-612, IC 601, C667,607,608 etc .
Dec 07, 2007 | Sony KP-53XBR200 53" Rear Projection...
I have a KP-FX53M91 Projection TV. When I switch it on with the remote, the light turns green but changes to blinking red. I have to repeat more than 15 times before the Tv comes on. Lalit Sodha
yes your problem is the high voltage power supply , on this problem you would has to hire a tech to fix this problem , the problem is a voltage control ic who turn on the high voltage if this is not working properly the tv never come on or sometimes take forever , normal repair cost is about 200-250
Aug 17, 2012 | Sony KP-53XBR200 53" Rear Projection...
Timer/stand by light is on but no picture. Un plugged and plugged then the light blinked but still wouldn't turn on.
How many times does the led blink in between pauses? Thats an error code if it repeats a blink sequence.
Mar 28, 2010 | Sony KP-65WS500 65" Rear Projection...
My Sony tv screen blinks off and on and timer/standby blinks 5
Yes....this blinking code is a diagnostic fault code which is a good thing, you count the number of blinks and it tells you where the problem is.....you also can see it by pressing the buttons, DISPLAY,CHANNEL,5,volume - not + ,then power....In your case it blinks 5 times,its in the video out,you need a desoldering iron,solder,rosin core 60%tin and 40%lead...remove and replace these,Q761,Q705,Q732 on the C board also Q218,Q219,Q220 on the A board.hope this helps.......
Feb 26, 2010 | Sony KP-53HS10 TV
Problem for Sony KP-57WS520 57 in. Rear Projection HDTV-Ready... Stand by light flashing, TV will not turn on
need to know the number of blinks as thats an error code. it should blink a series of blinks pause briefly then repeat the sequence.
Nov 23, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony tv suddenly turned off with the timer light blinking ,and it cannot be turned on again
How many tomes is the timer blinking? It should blink a certain number of blinks pause briefly then repeat the process.Thats an error code
Nov 23, 2009 | Sony KP-51WS500 51" Rear Projection...
2004 Sony 52" Wega dont turn onnthe stand by light stays flashing. This TV first started by taking long to turn on and now and then would turn off until one day it just didnt turn on and the standby button...
When that model Sony shuts down the LED starts blinking as you say but it is telling you something because it blinks a certain number of times and then pauses and repeats the number of blinks. Count the number and then I might be able to help you narrow down where the trouble is.
Jun 14, 2009 | Sony KP-51WS520 51" Rear Projection...
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53XBR200 53" Rear Projection Television Logo
942 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
