Question about Nokia 3310 Cellular Phone
Off/on switch jumper(where the switch is soldring in the PCB . the print is broken)
    Problem Solver:
  • 5 Answers
Nokia 3310 on off switch jumper
Posted on Oct 19, 2011
The same control PCB is used for the refrigerator and freezer, but the setting of the PCB is 1 if fitted in a freezer and 0 if fitted in a refrigerator. Does anybody know how to change this setting?
Look for a jumper much like the kind you find on Hard drives and computer motherboards. If there is one. there will be indicators printed on the board.
Jun 17, 2015 | Turbo Air M3R47-2 Reach-In Refrigerator
Brother 420
error 51 = The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Fix is
Switching arm assembly not engaged correctly If the switching arm does not move smoothly, clean it.
Ink cartridge/purge switch harness not connected correctly
Correct the connection.
Purge cam switch broken Replace the purge cam switch.
Gear(s) on the maintenance unit broken Replace the maintenance unit.
Paper feed motor broken Replace the paper feed motor.
Main PCB defective. Replace the main PCB.
Cleaning of these print heads rarely if ever is successfull, they are electronic devices unlike other brands of printers
Dec 04, 2007 | Brother MFC 420CN All-In-One InkJet...
Need spares website details as PCB is broken
if the printed circuit board is broken you need to solder new wires across the places where the copper traces have been broken because of the break
Feb 19, 2015 | Office Equipment & Supplies
How to clear "unable print 51" in Brother MFC 230c printer?
Switching arm assembly not engaged correctly Ink cartridge/purge switch harness not connected correctly Purge cam switch broken Gear(s) on the maintenance unit broken Paper feed motor broken Main PCB defective.
Jul 26, 2014 | Brother MFC-230c Printer
Init unable 50
Set the maintenance unit into place, if the planetary arm does not
move smoothly, clean it. purge cam switch harness not connected correctly,correct the connection,purge cam switch broken replace the maintenance unit, gear(s) on the maintenance
unit broken paper feed motor defective replace the engine unit,
power supply PCB defective replace the power supply
PCB. Main PCB defective replace the main PCB.
Dec 02, 2013 | Brother DCP-195C Inkjet Multifunction...
I have one nokia1110 mobile phone. When i make or receive a call i can hear the voice of the person speaking but no one can hear my voice . need a solution
open pcb & select multi meter at ohmic value
check connectivity on mic pad at pcb if shows anythink connectivity just replace mic if does not shows anythink when you checked connectivity find wich contact are brokened
Method;how find wich pad are broken
place one probe of multi meter on pcb ground & check both pad of mic on pcb when does not shows connectivity on any pad of mic remember it after that arrenge other same type pcb & place any probe on mic pad that you identified & check connectivity at near about when shows on multi meter full conductivity & remember it now resold jumper between mic pad & that part that you searches in your foulty circuit board
Jul 09, 2010 | Nokia 1110 Cellular Phone
Unable to clean checked paper jams there are none cant print
If there is no jam it is generally a mechanical issue such as...
1. The switching arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the tiniest of cracks but ruins everything!
Jan 31, 2010 | Brother Office Equipment & Supplies
Epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Jan 09, 2009 | Epson LQ-2180 Dot Matrix Printer
I forgat
hi you can open it and take out a battery for 5 min
Oct 21, 2008 | HP OmniBook XE3 Notebook
Set up a mouse
It seem dry soldring of button to pcb
Mar 03, 2008 | Dell U0636 Mouse
Nokia 3310 Cellular Phone Logo
460 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
