Question about Maytag Atlantis MDE7400AY Electric Dryer
Plastic wing inside the drayer drum fell
Plastic wing inside the drum dryer fell (Atlantis dryer). A smell of burn was for few minutes and disappeared.
  • ynhrnew May 28, 2008
    Thanks. Where can I buy a fin? Is there any instructions on how to open the box?
    Thanks. Where can I find new fin and where can I find installation guide?
  • 868 Answers
Replace the fin if you have found that it is broken.
Posted on May 28, 2008
Dryer makes grinding noise after a few seconds of spinning. Doesn't happen at start, and burning smell is coming out. Help?
Not sure what brand dryer you are talking about but it sounds like it could be your drum bearings in the back of the drum or it could be the plastic bearings in the front of the drum or it could be the rollers or at least one of them may be bad.
Nov 16, 2015 | Dryers
Maytag atlantis dryer
The belt is worn out. Have the whole unit cleaned, and the bearings checked.
Nov 22, 2013 | Dryers
All the clothes in my dryer dry at a normal time, but the smell burnt! After a dry cycle, the inside of the dryer smells like something is melting, but everything seems to be working correctly. We have had...
Remove the vent duct at the back and clean out all of the lint. Next, find the air inlet to the heater elements and make sure there is no lint accumulated there. Inspect the back of the drum (inside) for any plastic debris (something left in a pocket?) that might have melted and stuck on there. Last resort: remove the dryer cabinet and drum, and inspect the heater and its wiring. If the insulation on the wires appears burned or is broken off, cut off the damaged part of the wiring and replace its terminals, then polish the heater terminals before reattaching the wires (a tarnished connection will cause the wire to overheat). Clean out the heater if necessary, but be careful not to stress the heater element. Used heater wire is brittle and cracks or breaks easily.
Jul 04, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer stop working, it made a big noise and is not spining anymore, ts sounds as if it is out of place or something, and after 3 minutes it starts smelling like burn My dryer is a Maytag...
TRY SPINNING THE DRUM BY HAND. IF IT SPINS EASY, YOU HAVE A BELT BROKEN.
MOST LIKELY THE BANG WAS WHEN THE BELT BROKE. YOU NEED TO PULL THE DRYER OUT, OPEN IT UP AND REPLACE THE BELT. A SERVICE APPLIANCE REPAIR WILL NEED TO BE CALLED. - - SORRY
Feb 20, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
MY DRYER VIBRATES VERY BADLY, THE CLOTHES STILL SPIN BUT THE WHOLE UNIT MOVES ALOT AND AFTER A FEW MINUTS IT STARTS TO SMELL LIKE SOMETHING IS BURNING.
This sounds like the rubbing strips at the front of the dryer are badly worn and/or the rear bearing is worn. From your description - the drum is sticking - causing the motor to slip on the belt - causing the burning smell.
Replace worn parts including the drive belt.
Aug 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My maytag dryer is making a very loud noise near the area where the belts are, the belts seem to be working and the drum is turing, however after a while there is a burning smell.
Is the burning smell like plastic? If so read on. The belt runs on a spring steel plat tensioner with platic wheels of course. Plastic is on everything these days, huh? Well anyways the wheels the belt rides against has bushings inside them to make them last a long time which they do. It seems the plastic wheel will melt down in some spots and when rotating it makes the drum of the clothes dryer make a rumbling sound. I know you did not mention that problem although if the wheels keep on melting down the smell will subside but the noise will get loader as time goes on.
Jan 25, 2010 | Dryers
Bottle cap fell into lint trap behind the drum,
take the top cover off the unit(after UNPLUGGING unit of course)screw location varies on units,some you need to remove front cover first to access screws for top
Aug 05, 2009 | Amana DLE330RAW Electric Dryer
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
New dryer smells
Some times in a brand new machine their might be packaging that was left underneath I would disconnect vent,unplug and tilt to be able to look under it
Sep 07, 2017 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
179 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
