Question about Iolo Technologies System Mechanic Professional: Windows
I get a 323-a error message when I am trying to instal sytem mechanic.
  • 67 Answers
Well this message does come up in many ways and to trouble shoot the problem have to know the OS, modem, and when the initial error occured, after downloading some new program etc.
Posted on Oct 03, 2010
Tip
System mechanic or professional failure code 323-a
This error comes usually on system with Service pack 3.
The reason why this message comes on the system is the service pack 3 is either currpted or not installed properly.
" The 323 error can occur when using the Standard Edition release of the 1.0 version of the Microsoft Systems Management Server program. It happens when the Systems Management Server is used with the non-U.S.
version of the Microsoft SQL Server version 4.21a. The 323 error appears in the Systems Management Server event log. It is logged because of a discrepancy in the settings for the two programs. The required time and date format for the Systems Management Server is different from the format used in the SQL Server. It may happen when the
French version of the SQL Server is installed on a U.S. version of Windows NT wherein French is the default language used for the SQL Server "
Do the steps to fix this problem:-
For windows XP :- ( If you have service pack 3 installed on your system )
1:- Remove the Service pack 3 from your computer :-
Click on start-->go to Computer--> Go to C drive ( Primary Drive )--> Go to windows -->
If you find some hiddens files find out $NtServicePackUninstall$ folder. If you do not find it Stop here.
If you do find it Do this:-
open $NtServicePackUninstall$ ---> open spuninst ---> double click on spuninst.exe
( Exact Path :- C:WINDOWS$NtServicePackUninstall$spuninstspuninst.exe )
Now follow the instructions and uninstall the service Pack 3. During the uninstallation of Service Pack 3
It might would prompt you that some files or services will be affected after uninstalling the Service Pack 3
Do you want to continue. So at this point DO click on yes and continue with the uninstallation.
If the uninstallation is succcessfull. Restart the computer and then try to install the system mechanic professional
or system mechanic again.
If the uninstallation of service pack 3 is unsucccessfull
Try this:-
Do a system restore and then try to uninstall the service pack 3 using the above steps.
If even then you are unsuccessfull then do this:-
Save your imporant files and documents on an external hard drive and Format the hard drive completely.
Now try and install the system mechanic professional or system mechanic. you will successsfully install it
for sure.
If the uninstallation of service pack 3 is succcessfull
Do this:-
Try to install the software now. If it works perfect. Else do this :-
install the windows installer 4.5 using the link below.
[ http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&displaylang=en ]
downlaod the executable file given below on this page:- ( WindowsXP-KB942288-v3-x86.exe )
After installing the windows installer try again to install the software. If it works perfect. Else
Try this :-
Now re-install the Service pack 3 again. using the below link:-
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en ]
This may take a long time. But after installing the service Pack 3 again.
Install the software again. If it works perfect else
Do this :-
for sure.
If this does not work either call system mechanic people using the number 323-257-8888
For windows vista :-
Try to do windows Update and then try to install. If does not work then try to create a new user account and then
try. As some times the user account is also corrupted.
For windows 7 :-
Do windows update and then try installing the software if does not work then try
calling the system mechanic people using the number 323-257-8888
Note :-
( For windows 7 and vista we still are doing a research once we are done we will put that online.
In the mean while follow the instruction given above. )
on Jun 24, 2010 | Computers & Internet
Keep getting Printhead and Ink Cartridge error message. Have installed two new printheads; still getting error. Error started after downloading latest firmware and software for the printer. Kodak disavows...
To find out whats the cause of the problem try to go to event viever for clues in device manager (right click My Computer the click devive manager then go to event viewer, go to sytem and check under the Source column for Print errror. Print errors are always seen via the Print word under the source column. Now check for any clues you can google on the net. or simply uninstall new firmware.
Sep 04, 2009 | Kodak 5300 All-in-One InkJet Printer
Winodws sytem 32 file not found
Have you got an Anti-Virus program installed , do you have an Anti-Spyware program installed
If not when you get this machine running again go to www.filehippo.com and download Avast and Spyware Blaster
To get it running go to
http://support.microsoft.com/kb/307545
Jul 01, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
Error msg "The system chassis was opened" how to continue booting
firstly, you have to close the side panel after install any component. if the message show you again, try to find and short connect the jump (2 pins, signed Chassis) on your mainboard.
Feb 17, 2009 | Intel D945GCZ Motherboard
Wacom Graphire 4.40 Install question
Make sure you have no old Wacom drivers installed in your applications folder. If you do, then you will need to uninstall each driver via the "remove tablet" utility.
Oct 13, 2008 | Wacom Graphire4 Digital Pen
While I am using my laptop I keep getting a blue screen with the following message: DRIVER_IRQL_NOT_EQUAL_OR_LESS TECH INFO: STOP: OXOOOOOOD1 (0X00000008, OXOOOOOOO2, 0X00000000, 0X80C0ED5B) ...
hello
That error is cause by hardware and software's conflict this can be resolve using this solution.
Boot your system in safemode and remove the newly installed software. Or try start you sytem by selecting last know good configuration.
If not solve the problems maybe you should reinstall the system, the operating system.more info in installing windows here; http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
best regards,melnavz
Apr 02, 2008 | Computers & Internet
Iolo Technologies System Mechanic Professional: Windows Logo
262 people viewed this question
Top Iolo Technologies Computers & Internet Experts
Jax Planet
Jax Planet
Alun Cox
Are you an Iolo Technologies Computer and Internet Expert? Answer questions, earn points and help others
