Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series
I checked the seal from the water basin and it is tight. For some reason I'm not getting any water from the basin into the hose. I can't see how to take the white water basin apart to see if it is clogged. The only access to it is through the small hole in which to fill it.
Thanks for everything.
    President:
  • 2,712 Answers
If you have the Rainbow e series, then this manual will explain exactly how to remove the separator from the wash basin and the basin from the caddy. (Please refer to page 6)
http://www.rainbowsystem.com/pdf/manuals/rainbow_eseries/eseries.pdf A special tool is stored on the underside of the power unit next to the separator , which you can use to loosen the brass nut holding the separator.
The manual also provides instructions on how to remove the basin and clean it.
In my opinion, it is most likely a blockage in the tubes that must be causing this problem. This seems to be a common issue with this cleaner. There is also a small metal ring between the separator and basin that may be dislodged and causing this problem. Please the manual for an idea of what I am talking about.
If that does not help, then its best to contact the customer support.call, (248) 643-7222,
Monday through Friday,
between 9:00am and 5:00pm (EST)
and ask for Customer Service.
If you find that this answer helped you in any way, please "Accept" my solution in the premium you posted at
http://www.fixya.com/support/t624973-rainbow_e2_aquamate
I would be most grateful for your show of appreciation. Thanks in advance and good luck!
Posted on May 27, 2008
Why rainbow vac wont turn on
There are numerous reasons. If there was no smoke or burning smell, first try a different outlet. Then you can try wiggling the cord and check cord for damage, if you can get it to start and it turns off again cord is loose or damaged. Try the switch, sometimes switch wears out, if it is not making a click sound or is very loose it may be the switch. The most common reason for an E series to not start after working just fine is a broken actuator on the water basin or missing from the bottom of the vacuum. There is a raised part on the water basin that depresses a little black plastic actuator on the bottom of the vacuum. This is a safety switch to make sure the water basin is there so the vacuum will turn on. You can try pressing in on that and trying to start your vacuum, if it starts you will need to check and see if the part is broken off of your basin or if the little black actuator is missing. You can see pictures here.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 10, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Cannot separate water basin from motor
You need to unlock the latches on either side of the water basin.
If they rusted or froze into place you may have to break them.
There are two latches on either side of the water basin.
Rainbow and E2 latch
GoodVac.com
800-775-6586
Feb 16, 2014 | Rainbow E series Canister Wet/Dry Vacuum
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow has no suction
Your Rainbow E series has lost suction power, because you need a new hepa filter, or your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
If it is an earlier model, everything applies, except for the filter. They do not have filters, on any of the earlier models.
Thank you,
Ralph
Jan 27, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My e series rainbow smells very badly... my teenager often leaves the water in for days and that nasty smell has saturated the sweeper itself. How do I get the smell out
You should always put a new hepa filter in any E and E2 series Rainbow vacuum, when it taken to a new home, or every two Years, or so, or if your Doughter makes it get funky smelling. :-) It will smell like the home that it was in, or how ever it smells, until you do.
You can also use fragrances, and deodorizer air freshener in your vacuum, which not only eliminates odors, it add fresh aromas to your air that you breath, in your home, also.
Replace the hepa filter first thing.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
Thank you,
Ralph
Jan 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How to maintain up keep on my rainbow vacuum
Be sure and never store on water basin, keep separator and seal on bottom of rainbow clean. Keep your beater bar clean. You should be good for many many years.
Jul 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
May 25, 2009 | Rainbow 75th Anniversary Canister Vacuum
I have my vacuum set to shampoo a rug, but cannot get the water to come out
Sometimes it takes up to 10 or so minutes for the Aqua mate 2 to begin pumping out anything.
If it is the new Aqua mate 12 (the big blue one, that is like a giant power head) the same thing is true for it.
If it is an earlier model Aquamate, then it is clogged somewhere in the hose, or the fluid control valve is clogged.
Thank you,
Ralph
Jan 25, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Jan 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
227 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
