Question about Audiovox FPE3000 30 in. HD-Ready LCD Television
Problem with screen
Screen won't turn on -- just black. We hear it come on and the red indicator "light is on, but no one's home".
  • sexylo Jun 05, 2008
    i had the same problem, when i put the tv in the shop i found out it was the power adapter it was no good.
Mine did the same thing and it was the back light board. Good luck getting one. I had to threaten to sue them and badger Audiovox until they mysteriously had one. Now my power suppy is bad at least I got another year out of it. This TV SUX!
Posted on Sep 09, 2008
How can I repair my LGSMART TV?
hi sounds like failed led or leds in the panel, thanks
shaun
Mar 02, 2017 | Televison & Video
How to repair LG TV
The power supply may have failed.
Nov 07, 2014 | LG 42LM3400 42" LED Cinema 3D HDTV w/ 4...
Posiflex jiva tp5800 screen turned red on the bottom and now its black
This is related to the backlight of the lcd screen. It could be the light itself or the inverter. The parts are available: http://www.posiflexusa.com/SP_LCDRepairKit.php
Nov 24, 2013 | Posiflex Jiva 5800 All-In-One...
I dropped my samsung galaxy s 2.. it won't power on.. the lights at the bottom come on briefly.. but the screen stays black.. I can hear it power up somtimes but the screen remains black. Can I f
Take off the cover, remove the battery and use a pencil eraser to clean both the battery plug pads and the plugs in the phone. Get a piece of thin tape and apply to the bottom of the battery and then reinsert. Try to power up. Sometimes dropping it will slightly bend the batter contacts or misalign them. Clean and see if that helps.
Jan 06, 2018 | Samsung Galaxy S II
When I turn our tv on the power light comes on but the screen is still black and there is no sound.
Black Screen - Sometimes, the TV may display a black screen, now you need to check the cables whether they are properly plugged or not. Reconnecting all the cables can also work for this problem. Also, if the screen has a screen saver, check how it's set up. And, if nothing works for this issue, then there is a possibility that the lamp, rear projection, or the LCD panel may have been damaged. Now, you need to check your warranty card of your television and se your set comes under the manufacturer's warranty period. Call the customer service for technical problem and get replaced if a part demands it.
consigning no sound on your TV
You might need to do some troubleshooting tips first before calling arepair man to replace the sound IC inside the TV.
Check the volume setting. It might sound simple, but it's the best place to start. Make sure the television sound is not muted or turned all the way down using the remote or buttons on the front of the television. If the batteries are dead in the remote and the TV is muted or turned down, it might seem like the sound is broken.
Examine cables connected to the TV. Sometimes a loose connection can cause a loss of sound. Ensure all cables are tightly connected to the television and correctly inserted. Some peripherals are connected using a three-plug system and are usually labeled red, white (sometimes black) and yellow. Both the red and white leads are sound cables. Try removing all the cables (except the power) from the back of the television and turning it to TV mode, then listen for static or other sound.
Plug in headphones to the television with all cables re-attached. See if you can hear sound through the headphones. If you can, it may indicate that the TV's internal speakers are not working. If you can't hear anything through the headphones, it may be indicative of a larger problem.
Call a repairman. If at this point everything has failed to produce a sound, it's time to call in the professionals. A qualified technician should be able to fix the problem either at your home or in a workshop.
May 25, 2011 | Televison & Video
My panasonic t.v. turns on but has a black screen
How many times does the light blink? Thats a error code indicating what the problem is.
Apr 15, 2010 | Panasonic PT-56TW53 56" Rear Projection...
Black Berry Pearl Black Screen with alternate flashing lights
MY PHONE ONLY DISPLAYS A WHITS SCREEN AND A PICTURE OF A BATTERY WITH A RED LINE CROSSED THROUGH IT WHAT DOES THIS MEAN DO I NEED A NEW BATTERY OR ? HOW DO I RESET MY PHONE ?
Jun 28, 2009 | RIM BlackBerry Pearl 8100
Flash red then nothing
Te projection light bulb has blown out they are suppose to be good for about 2000 hours and cost about 250 US dollars
Sep 30, 2007 | LG RU-52SZ51D 52" Rear Projection...
Audiovox FPE3000 30 in. HD-Ready LCD Television Logo
115 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
