Question about Olympus Audio Players & Recorders
I have a very old sterio3 in one Pioneer MS6500. I am looking for a stylus for this model
What can I use to replacemy stlus/needle?
You'll need to do an internet search for a compatible Stylus that was made for your record player. It has to match exactly. It doesn't necessarily have to be made by the same maker though, just compatible.
A search using the words "Pioneer replacement stylus" gets you: http://www.needledoctor.com/Contact/Pioneer_2 and many, many more. Try "Sanyo replacement stylus" and you get http://www.styli.co.nz/sanyo.html.
There's lots of them out there for every manufacturer/model.
Better yet, try to look up your stylus part number in your owners manual, if you still have the old one look for a part number on it. Then look it up on EBay or Amazon. It's a lot easier to track one down if you can find the part number of the original part. Since you didn't list what model record player you have you'll just have to start with the manufactures name and start from there. Lots of companies are still out there that sell them. Good luck.
If you need more help let me know. I'll be glad to try and find one for you. I'll need the manufacturer of the record player and the model number.
May 11, 2014 | Audio Players & Recorders
I don't know what needle is needed for my pioneer turntable PL-X88Z?
You just need to look at the cartridge and look for the make and model number. Once you have that you can search Google for it and the stylus will also show up.
Sep 26, 2013 | Pioneer Audio Players & Recorders
Pioneer pl 1170
Look up the cartridge number and search Google for that. You will find the correct stylus from that.
Sep 05, 2013 | Audio Players & Recorders
Pioneer plz85 needles
You need to look at the model number of the cartridge fitted. Put that into Google and it should come up with the replacement stylus.
Jun 20, 2013 | Pioneer Audio Players & Recorders
Stylus for my pioneer hi fi record player
Look at the Cartridge fitted. It should have a make and model number on it. Type that into google and the right stylus should appear.
Mar 17, 2013 | Audio Players & Recorders
I have a pioneer marantz model 6100 and need a new stylus. It's yellow. Ways the name of the stylus needed?
Check http://www.manualowl.com because they may have the free PDF to see if mention of stylus model # and contact info for ordering.
Apr 11, 2012 | Pioneer Audio Players & Recorders
About 11 months ago I bought an Elliptical upgrade stylus for the PL-990 and it worked great. Recently, it started giving me problems. The left channel would be very distorted and also would fade in and...
Very odd! Sounds like it's not fitting in right. Are you sure that you have the right type of stylus for the cartridge? If in doubt replace the entire cartridge & Stylus. If it still plays up then it's in your amp after that course of action.
Aug 18, 2011 | Pioneer PL-990 Turntable
Looking for a stylus for old sansui turntable model FR-D25??? Any suggestions
It is next to impossible to find a replacement stylus, I suggest replacing the cartridge which will include the stylus giving you the flexibility to make a choice on what you prefer.
Mar 19, 2011 | Sansui Audio Players & Recorders
Looking for instruction manuel for old pioneer cd burner
DDownloadfrom this link
https://www.manualslib.com/download/585528/Pioneer-Pdr-L77.html
Jan 09, 2018 | Pioneer Computers & Internet
Magnavox Stylus
We need to know the model number of the CARTRIDGE itself. Doesn't matter what turntable you have. All that matters is what cartridge is mounted on the turntable, so that we can match the correct stylus. The stylus/needle connects to the Cartridge:
As the diagram shows, the stylus mounts to the cartridge, which then mounts to the headshell. This headshell is then connected to the tonearm (tube).
So, if you look at the cartridge you should be able to see the model number. If not, there is no way to match up the stylus, as ther are literally THOUSANDS of styli on the market. I would suggest purchasing a NEW cartridge/stylus combination. The following should fit your model:
UNIVERSAL MOUNT CARTRIDGES
- Davis
DJ Pro Audio
www.djproaudio.com
Aug 10, 2008 | Philips Audio Players & Recorders
108 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
