Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I cannot get a DVD disk to play loud enough to listen to comfortably. The same disk will play well enough on another HD tv-set. Is it my ancient DVD player, lousy cables, or a setting I am not getting right on the Aquos?
  • rslevy Oct 03, 2010
    Will see if it is useful shortly. I appreciate that it is clear advice, simple enough for a technologically challenged person to grasp. Therefore, I accept.
    President:
  • 2,777 Answers
It could be cables, but unlikely, definitely not a setting on the Aquos, it could be a setting though on your old dvd player. Go into the DVD player menu / setup and look for SOUND / VOLUME and many times it will have an adjustment such as +1 +2 +3 and 0, then -1, -2, -3, meaning thats how much it amplifies the default sound of the DVD. Turn this up all the way to the highest setting, it should have something like this. If not then I would replace the DVD player.
Thanks Tim
Posted on Oct 03, 2010
How to set up to using hdmi
#1 your tv would need to be hdmi compatable (have the appropriate plug on the back where all the inputs are located). For example I have a 60" Lcd HDTV and an xbox360 I attached the standard a/v (audio/video) red,white,yellow wires to tv and turned on the game console went into system settings and turned on the hd setting to 1080i for hi def resolution. Another alternative would be to connect console to your dvd player (most new dvd players will up convert signal from 480i or 720i to 1080i hd) and attach your hdmi cable between the dvd player and the tv to support the hd interface. Something I highly recommend is the jvc th c50 home theater surround sound when I play call of duty it has enough to knock stuff of our bookshelves and ******** the neighbors. Happy gaming
Dec 09, 2010 | Video Game Consoles & Games
Thompson DVD DTH271E refuses to play HD DVDs but fine normal DVDS, cant seem to get any help via Thompson, & think may need "firmfare" update? New machine but in Spain & language...
Hello there.
Push "Play/Pause" and "DVD Rec" on the dvd recorder a few seconds to see the service menu. There you can find your firmware version.
Post back the version for us.
Hope this helps.
May 06, 2008 | Televison & Video
Hi, I'm getting only 720x480i resolution with component cables connecting this DVD and TV. My TV is full HD TV, but I cannot get 1080p with component cables. Tried almost every setting on TV and DVD.
720 is the usual output from a DVD. Usually if you futz with the settings long enough, you'll find where most TVs can at least fill the screen by re-sampling, and SOME DVD players will have settings that will do the re-sampling for you and output 1080i, again just to fill your screen. But don't be fooled... only Blue Ray disks will give you true 1080i resolution. .
Oct 14, 2010 | KLH DVD8350 DVD Player
I have philipd\s dvd player model no. DVP3126K/56.
Check with other DVD disks, see if it play,might have bad disk in that one,like scratches,cracks,or smushes.The disk u playing is a chamerical DVD Disk right?Not burn disk?Might just go in Ur DVD player just reset every setting back to the factory setting.
Oct 31, 2009 | Televison & Video
Toshiba 52" REGZA has a grainy picture
There is no easy (read: cheap) solution for this. Especially because your TV is so big, the only thing that will look good on it is something that plays at the very least 720p HD output.
I don't know what your DVD player model is, but you want an upconverting DVD player, and even then, the quality will not be full HD. The only thing that is full 1080p HD on the market today is Blu-Ray, and game consoles like XBox 360 and PS3.
As for the sports, it depends on the TV you bought. If the deal was too good to be true for a 52" TV, you probably got one with a low Hz, or a high refresh rate. This means that the images played don't update quick enough for high motion video like action movies and sports, which is why it's blurry. Mine has a 3ms response time, by comparison.
Hope this helps, please rate me.
Feb 21, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
I think a connectivity problem with tv and dvd player
dvd playes or hd dvd players will not play blu ray diskd you must have a blue ray player to play blu ray disks
Dec 02, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
VCR/DVD setup for color on LCD TV
check to see you have the cables required by the tv. usually you need hdmi or dvid for hd display. digital rights management protocols have resulted in chips in playing devices that allow only the use of the referenced cables to protect content from being copied. in some sets they default to not playing in hd, but still play something.
look there first, otherwise you may have an input source mismatch. follow instructions on the dvd player first, then make sure the tv has compatible settings.
if that does not solve, you have a service issue with one or both.
good luck
mark
Dec 17, 2007 | LG 42LC2D 42 in. LCD HDTV
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
79 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
