Question about NetGear MR314 802.11b
Router interference from multiable neighbors. how to resolve problem.
  • NetGear Master
  • 32,281 Answers
To resolve this problem, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Posted on Oct 03, 2010
Wy my roku is frozen evry evning from 6 pm to9 pm its sad loding and evry 15 seconds
If your ROKU keeps loading it is probably because your internet speed is too slow or your router is too slow.You might be getting interference from a neighbors router.Try getting a dual band router.
Feb 24, 2016 | Roku 2 XD
I keep losing ADSL and WiFi connection.
Try using another channel, like 11. Cordless phones interfere, even your neighbors.
May 13, 2011 | Zhone ADSL2+ 4PORT 11BG 400MW PERPWTR069...
I keep losing my internet connection when I use the wireless router. When I disconnect the wireless router, internet works great but when I reconnect it it keeps cutting out. I unplug it for ten seconds...
Try changing the channel to 11. Cordless landline phones often interfere with the default router channel. It can even be your neighbors phone that is conflicting.
Feb 06, 2011 | D-Link DIR-615 Wireless Router
I am having a problem with a netgear wireless router (WPN824v2), and getting no help from them as the product is refurbished. It is kicking offline, and interfering with my phone (Clear Choice phone...
Improving Wireless Range: Tuning Equipment
Using the best channels has a big effect on network performance. Your goal is to choose settings that avoid interference from other networking and radio frequency equipment. (If you have 802.11a or 802.11a/g, channel selection is less important, skip to "Reducing Wireless Network Traffic".)
To see all your options start with: Improving Wireless Range: Overview
If you have a simple home network, and aren't close to neighbors with wireless equipment, you may be lucky enough just to choose between many channels that work well.
Complications arise when:
  • You want much better coverage than you're getting.
  • You use multiple access points or wireless routers. (Then you'll probably be using more than one channel.)
  • You aren't the only person nearby running a wireless network.
Simple Spacing of Channels
As explained in Improving Wireless Range: Overview, improving signal strength is not like adding more lights to get a brighter livingroom. Devices that transmit powerfully - such as routers, access points, and cell phone base stations - confuse one another. It's necessary to distance them and to have them use different channels.
For 802.11b and 802.11g, there are 11 channels for wireless equipment (13 channels in Europe). In the simple situation where there's little interference, you can choose any channel that works for you. When there is interference from wireless networks that overlap with one another, each network should use one of the non-overlapping channels: 1, 6, or 11 (1, 7, 13 in Europe). Then, 3 networks can use the same space with minimum interference. If you can't do that, choose channels as widely spaces as possible.
You can use a combination of access points and antennas and other equipment to create local "spotlights" of strong transmission, rather than trying to cover everywhere.
What If a Channel I Want to Use Has Too Much Noise (Interference)?
If your neighbor has a wireless network, it wouldn't be surprising that they are already using channel 1 and channel 11. Unfortunately, you can't completely avoid interference just by using other channels. Wireless protocols 802.11b and 11g only have 3 non-overlapping channels. Therefore when 4 or more channels are used in the same area, the level of interference can increase notably. If you and your close neighbor both have a router and a wireless access point, for example - which makes a total of four powerful transmitters - both of you will have a certain amount of interference.
If there's a severe problem, a practical and sociable thing is to talk to your neighbors using wireless networks that can be seen when you scan. Together, you can choose optimal channels for your respective networks. You'll want your own channels at least 5 apart. So, for example, you could use channels 1 and 8, and your neighbor could use 5 and 11.
You may be able to place routers and access points further away inside your homes. After all, the kinds of physical barriers that reduce your transmission range also reduce the signal that your neighbor doesn't want to see.
Super G technology is faster, but it uses two, non-configurable channels. Therefore it may not be possible to pick other channels that avoid its interference.
If you can use a directional antenna, or an antenna cable to shift an antenna, that can help you both. See the articles on antenna selection.
When there's noise, your network performance drops, so one approach is not to stop the noise, but to reduce the amount of network data being transmitted.
In a noisy environment, it may be useful to keep part of your network wired. If Ethernet cabling isn't an option, consider NETGEAR's Powerline products - using existing home wiring instead of cables.
When SSID Broadcast is turned on, it's easiest for equipment to find the strongest signal. However this also causes network overhead. When the SSID is broadcast, your neighbor's equipment may keep a record of it, and automatically try to connect several times a second; this can cause significant performance reduction. So where there are close networks, turn off SSID Broadcast, and change the default SSID.
Turning off WEP and WPA may increase network throughput, but exposes your network to hackers. This is not recommended, except for testing purposes.
Nov 09, 2010 | NetGear RangeMax WPN824 Router
Using linksys wrt54g router i using the wired section with two computers and the signal only dropping
There are many causes for poor wireless connections, and many solutions:
First of all, give your network a unique SSID. Do not use "linksys". If you are using "linksys" you may be trying to connect to your neighbor's router. Also set "SSID Broadcast" to "enabled". This will help your computer find and lock on to your router's signal.
Poor wireless connections are often caused by radio interference from other 2.4 GHz devices. This includes wireless phones, wireless baby monitors, microwave ovens, wireless mice and keyboards, wireless speakers, and your neighbor's wireless network. In rare cases, Bluetooth devices can interfere. Even some 5+ GHz phones also use the 2.4 Ghz band. Unplug these devices, and see if that corrects your problem.
In your router, try a different channel. There are 11 channels in the 2.4 GHz band. Usually channel 1, 6, or 11 works best. Check out your neighbors, and see what channel they are using. Because the channels overlap one another, try to stay at least +5 or -5 channels from your strongest neighbors. For example, if you have a strong neighbor on channel 9, try any channel 1 through 4.
Also, try to locate the router about 4 to 6 feet above the floor, in an open area. Do not locate it behind your monitor or near other computer equipment or speakers. The antenna should be vertical.
Also, in the computer, go to your wireless software, and go to "Preferred Networks" (sometimes called "Profiles" ). There are probably a few networks listed. Delete any network named "linksys". Also delete any network that you do not recognize, or that you no longer use. If your current network is not listed, enter its info (SSID, encryption (if any), and key (if any) ). Then select your current network and make it your default network, and set it to automatic login. You may need to go to "settings" to do this, or you may need to right click on your network and select "Properties" or "settings".
If the above does not fix your problem, download and install the latest driver for your wireless card.
Some users have reported improved wireless performance by switching to WPA encryption.
If you continue to have problems, try the following:
For wireless g routers, try setting the "Transmission Rate" to 54 Mbps.
If you still have trouble, download and install the latest firmware for your router. After a firmware upgrade, you must reset the router to factory defaults, then setup the router again from scratch. If you saved a router configuration file, DO NOT use it.
Aug 24, 2010 | Linksys Wireless-G WRT54G Router
I show full signal on my laptop but the wireless lags or doesnt connect, and sometimes shows limited access ! What does this mean?
Other wireless devices in the home or from a neighbor can interfere with communication. try changing the channel in the router settings
May 31, 2010 | Linksys Wireless-G WRT54G Router
Cannot use the wireless feature keeps disconnecting often... need help how to fix the problem... neither can use the mobile to it..
Other wireless devices in your home or the neighbor's house can interfere with your router's wireless connection. try changing the channel in the router's config.
May 20, 2010 | Computers & Internet
Is there anything in a PC that can cause interference with a wireless network? Because firefox ate my earlier question, I'll keep this short: PC used to keep laptop from connecting to internet when it was...
there is nothing inside a PC that will keep it or anything else from connecting to a wireless network. You have to lookout for things that use the same frequency such as cordless phones and believe it or not microwave ovens. both broadcast at 2.4Ghz which is the same frequency wireless routers and access points use. Your problem may also be a neighbor with a wireless router or access point using the same channel. Wireless routers and access points have 11 different channels that they can broadcast on and if you and your neighbor are using the same channel there will be interference. try changing the channel on your wireless router or access point.
Apr 14, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
My laptop keeps dropping the wireless and I am having a hard time resetting - i can't understand why
There could be dozens of reasons for this. One of the most common is interference on a certain channel, often caused by neighbors's routers operating on the same channel. Change the channel on your router and see if things improve. Other sources of interference are 2.4MHz wireless telephones (even when on-hook), microwave ovens, and locating the router too close to a water heater or aquarium. The bad news is that reoccurring drops in wireless signal is also a common symptom of a failing router; you can sometimes diagnose this by unplugging and replugging the router's power cord the next time you experience a drop and see if the connection comes back without doing anything to the laptop.
Apr 02, 2010 | D-Link DIR-615 Wireless Router
I upgraded my Linksys WRV54G firmware from 2.39.2 to 2.39.2e and completely lost internet connectivity
hi there,
have you tried to reset your wireless router so that the default settings are being used, then try reconfiguring it again for your Internet connection.. then try to connect wireless again ... sounds like your router may have lost its settings which happens for some firmware upgrades.....
or
Wireless Interferences
Neighboring wireless networks or any appliance that operates on the same frequency as your wireless device (e.g. 2.4 GHz) may cause interference and therefore may affect your wireless connection and signal.
Common sources of interference are:
  • Neighboring wireless networks
  • Microwave ovens
  • 2.4 GHz cordless telephones
  • Bluetooth devices
  • Wireless baby monitors
To solve the problem, change the channel and SSID on your Access Point. Preferred channels to use are 1, 6 and 11 since they’re considered non-overlapping channels.
May 01, 2008 | Computers & Internet
NetGear MR314 802.11b Logo
125 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
