Question about RCA 32F531T 32" TV
32 INCH tv
TV doesn't come on like no power to the tube the on off switch was changed brand new the fuses are good changed some dials can't figure it out sorry on off switch comes on but the power doesn't go to the tube hardly any sound no picture on off switch just comes on then goes off a few seconds later then comes on again a few seconds later please help thank you.My TV is a 32 inch flat screen TV model # 32F531Y
  • Letieva Jun 15, 2008
    I don't want to sound silly here but what is a cpu explain thank you.
  • 85 Answers
The cpu of your tv is not working,coldsolder the mainboard of your tv and the cpu then get the voltage output of your tv.
Posted on Jun 13, 2008
  • roney  trejeros
    roney trejeros Jun 16, 2008
    you can see it from the mainboard of your tv,and maybe the switches of your tv are malfunctioned.
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Samsung AK59-00123A remote to a M261VP vizio tv
Hello
[1] Switch your television on
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
Sep 20, 2011 | Zenith ZEN700 Remote Control
32" TV fell over onto carpeted floor and won't
It's probably a write-off. The circuit board inside has been cracked so that some of the copper traces that connect parts have broken. This commonly happens around the area of the horizontal output transformer, which is heavy. The shock of the fall causes the transformer to bounce and breaks the board. Other areas too may have been damaged because of flexing. And worst, the picture tube can be damaged in a fall, so it either doesn't work at all or shows permanently distorted colors.
It's tough to find anyone willing to repair a set that's fallen. Many circuit board tracks are very narrow and hard to repair. Then it's difficult to know if all the damage has been found and repaired, so even if the set starts working a technician doesn't know if something else won't go wrong. And then there's that bad tube possibility; no technician likes to spend lots of time fixing a broken board only to find the set then needs a new tube. Trust me, this has happened to me several times during my career in TV shops.
Your best bet is to use this as an excuse to buy a new LCD or plasma TV. 40-inch models, a good size match for a 32-inch CRT (tube) model, are reasonably priced.
Jul 03, 2011 | Quasar SP-3233 TV
What can i do if tv's lamp no good?
This T.V. doesn't use a lamp. If you're referring to the picture tube, there is no fixing this other than making slim adjustments on the knobs on the flyback. Don't tweak it too much or it will cause retrace lines. However, in most cases a bad picture tube means its time for a new T.V.
Jun 07, 2011 | Sony KV-32FS12 32" TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
What would cause the sound on a lcd hdtv 32 inch flat screen tv to just stop?
What other device are you connecting to your tv and how are you connecting it?
If you connect via a single HDMI cable that may be causing your audio problem. Some Tv and STB have handshacking issues which can knock out audio and/or video. The only solution would be to replace the HDMI cable or switch to composite cables.
Dec 14, 2009 | Element Electronics FLX3220F 32 in. LCD TV
I have a toshiba 32 inch 1997 tv. When I turn32G90 it
It sounds like the picture tube may be weak (because it's orange) but it going to half ascreen is not caused by the picture tube but likely a vertical circuit problem. If this problem happened suddenly (going orange) then the picture tube is probably good and at least worth bringing in for an estimate.
Oct 06, 2009 | Televison & Video
After pugging in the tv i press the power button and nothing nothing at all.
Check the fuse which is in the back. It should look like a glass tube and the wire inside should reach all the way across the whole tube.
If fuse looks good, then the power supply may need to be changed
Jul 09, 2009 | RCA 32F531T 32" TV
32 inch sony TV flat screen
If you are able to do console repairs I would order a new power switch module the either plug or solder on and switch it out. Without trying the TV myself I might think that the tube could be bad as well, if it is just having start up problems.
Mar 11, 2008 | Sony KV-32S26 32" TV
RCA 32F531T 32" TV Logo
188 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
