Question about Haier Heating & Cooling
The water outlet drain leaks water. - Haier Heating & Cooling
  • 20 Answers
Its required to leak water thats the humidity being expressed from your home
Posted on May 27, 2008
  • pgspgh Jul 22, 2011
    It's amazing that manual says nothing about this. A floor unit that is supposed to evaporate water is useless if it's "required to leak water" all over the carpet, padding and subflooring. The unit is so close to the ground that you can't have it drain into something unless you put it up on top of something else. Useless product.
Unit is 12000 btu and leaking water
it has a hook up on the back,there is supposed to be a plug covering it and also supposed to be able to hook a hose onto it to drain the water,you have to drain them every day or 2
May 27, 2015 | Haier HPRD12XC5 Portable Room Air...
WHERE IS THE DRAIN FOR MODEL 52CEC309351AA
Find the drain outlet and use a wet vacuum on the drain line to pull gunk clogging the drain line out. You may need to reclean on more periodic basis. Problems with drain line gunk buildup vary with location airborn contaminants. Your water leaking could also be not a drain problem, but an air leakage by the seals in the unit installation. If unit is not sealed properly, warm moist air can leak in past bad or missing seals and come in contact with cool surfaces and condense water out and leak out of unit.
Hope this helps
Oct 21, 2014 | Carrier Heating & Cooling
Water leaking in floor board when a/c on in mazda mpv 2001
You probably have a plugged drain outlet for your under dash heater/AC unit....system is designed to drain moisture from AC evaporator core via the drain outlet...drain outlet is located under the hood
Thru the firewall and is a (approx) 1/2" dia rigid plastic tube. Sticks thru, toward the rear of the engine, about 1". It's located so that it spills (nice!) onto the most rear engine/tranny mount. There's evident rust to prove it. Try to remove it and the water should pour out . Try to locate the drain by looking where the arrows are pointing to on the pictures I am supplying
1d4363cf-13f8-4af3-a2b2-ecb08cfd6711.jpg 8b16ada2-2a73-4695-b050-f5e63bc38830.jpg
Jul 14, 2014 | 2001 Mazda MPV
WATER INSIDE THE REFRIGERATOR
Blocked drain trough or if its an ice and water machine, there could be a leak in the water tank which is usually situated behind the crisper drawers. Clear the blocked drain with warm water or remove spilt food which may have blocked the water outlet. If its the water tank leaking, you will need to purchase a new one.
Oct 20, 2013 | Refrigerators
Amana tandem 7300
What does it mean when a washer leaks from the bottom?
The pump will have an outlet or drain hose, an inlet from the tub and may have a circulating hose outlet as well. If you have water leaking from the washer during a wash or drain cycle, check the area of the drain pump. Look for signs of a loose hose clamp or a leaking hose connected to the pump first. Washer Repair Diagnostic Leaking Water Amana Whirlpool NFW7300WW
Jan 18, 2018 | Washing Machines
Our logixx 8 washing machine leaks water from the bottom when the programme is at drain/spin, water is being pumped to the outlet pipe but also flooding the floor from the bottom of the casing
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
http://www.espares.co.uk/advice/washing-machines/a/7
Sep 20, 2011 | Bosch Washing Machines
1. Water is leaking out from the bottom of the machine. 2. Also, wanted to know if you are suppose to manual pipe in water for this model........................thank you.............ong
The first part is that you need to check at the following for leaks.
1. Check for leak from the inlet due to poor water connection. check leak at the inlet valve.
2. Check for leak from the tub.
3. Check for leak from the drain pump/valve or the drain hose.
The second part is not clear but a connection for water and an outlet for drain is needed.( make/model not seen.)
Feb 19, 2011 | Washing Machines
I need to buy a service plan. There is some puddle of water under the washing machine - this needs to be resolved.
You need to first take a good look to see the point of leak.
If can be from the drain outlet, the drain hose joints, the hose to the outlet, the drain pump/valve or the main tub. If the leak is during the spin it can be failure of the drum washer- water seals- or bearings.
Jan 05, 2011 | Washing Machines
Leaks water from back
this is not a water leak ! it is the humidity in the room which collects as water and drains out at the back.keep a bucket underneath or attach a drain pipe to the outlet .
May 31, 2010 | Goldstar WG8000 Air Conditioner
Heating & Cooling Logo
156 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
