Question about Mitsubishi WT-46805 46" Rear Projection Television
I have a Mitsubishi Projection TV model # WT-46805. The picture on my TV looks like double vision or like a 3D effect. One day it was good and the next all bad. What can I do?
    Problem Solver:
  • 14 Answers
STK replacement time. Very common issue.
Check out http://www.tvrepairkits.com/xcart/home.php?cat=2606
Posted on Oct 03, 2010
I have a WT-46805 Mitsubishi rear projection tv. The screen was accidentally pushed in and now has a crease. It was also missing the protective glass in front of the screen. I also have a broken model...
Check following image taken from related service manual that shows how to take off front screen from WT-46805 tv.
Hope this info will help you.
Please click HERE to download service manual copy, if required. It has schematics, parts list, exploded views and all technical info of WT-46805 tv. (service manual is available for 2 days only)
Thanks.
Nov 13, 2010 | Mitsubishi WT-46805 46" Rear Projection...
I am attempting to connect a Verizon Fios QIP6200-2 HD set top box to my Mitsubishi WT-46805 HD TV using the Y, Pr and Pb RCA connections (no HDMI port on TV) I cannot get any HD channels to work.
The set will have two component inputs, one is NOT HD.
You want to connect to the DTV input which if you look from the back will be marked 480/1080 I .
Also double check the connections to be sure blue-red-red and green to green.
SD TECH
Aug 18, 2010 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Jul 28, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-4605 - picture going dark, comes back
Good Day, rflinker;
Please check for fluid on the TV's PCB's, look toward the front of those boards, ensure all cables are properly seated into their sockets.
Good Luck, big IRISH.
Jul 25, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mits 46805 - Replaced IC's now picture is dim!
Good Day, Nickb2b;
The IC's you installed will not cause a dark/dim picture......but I would like you to check two things:
1. Make sure you put all cables that you may have unplugged into their proper positions, the cables are marked with numbers, ensure all cables are properly seated,
2. Look for fluid on the PCB's.
Jun 21, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi big screen tv model no. wt-46805 year2000
Replace the convergence amp ICs. also shck the resistors coming out of the ICs
Jan 30, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsu 46805 - No picture
this model has loose connections on the yokes remove the front speker gril and a small cover wigil the wires alittle and see if the pic comes back on if so solder the bad connections and put fresh solder on the verticl ic too
Oct 18, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
133 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
