Question about Phantom EFX Reel Deal Slots: Mystic Forest for Windows, Mac
The game has been installed on my computer. the game launcher is not working. i click on the game to start and it will not start. i have tried running the launcher as administrator and have gone through all compatibility options. i have windows 7.
How to install The Prince Of Persia The Forgotten Sands requiring internet support in windows 7?
Yes the game requires an internet connection for the first time it is installed only for you to be able to activate the game and be registered on the Uplay servers or else you won't be able to play the game. If uplay is keep on crashing, try reinstalling it.
Oct 12, 2014 | Ubi Soft Prince of Persia: The Forgotten...
Tip
Solution for all of you who download games
Hi! Did you ever downloaded PC game, installed it, but couldn't play it cause you don't have original CD ("insert the correct CD, then try again" message)? Well don't worry. That's normal. All you got to do is replace the existing game launcher with the working one, called crack. If you got the crack when downloaded it, then copy the (game name).exe to the installation location. if it's the working one, you will probably get the message that says that you already have that same file in the installation folder, but replace the existing one with the copyed one. And there you go. Double-click that new launcher to play the game. If you didn't got the crack when downloaded it, then download it. Go to btjunkie.com and type the game name, but add crack on the end(for example "Sims 3 crack"). Find the one who was most downloaded, and who people think it work's then click the down arrow to download it.
on Jul 04, 2010 | Video Game Consoles & Games
Cant start ghost recon future soldier
Alright, after a few months of steaming; I managed to FINALLY find a way to stop people from getting an error code 2 whenever they launch a game like AC2 for the first time. First off, check to see if you have a folder in your program files titled "ubisoft". In there, see if you got a folder titled "ubisoft launcher". If so then delete it. If your like me then you might have not even had the damned thing installed. Before you go to reinstall it [or even install it for the first time]; let's do some cleaning first. Bring up regedit [type regedit into "search" in windows tab menu or search to learn how to bring it up. It's easy].
On your left; you should have a list of folders. DO EXACTLY AS I DO! Open HKEY_LOCAL_MACHINE then SOFTWARE THEN Wow6432Node then open the ubisoft folder in there. You'll see the game you installed Example would be Assassin's creed 2. Go to the folders titled "Launcher" and "Ubisoft Game Launcher". Delete both of them. DON'T WORRY! These stop the ubisoft game launcher from installing at all. It just crashes the installation no matter what you do. You can find the installer sometimes in the support folder in your game install dir but I never got mine. Instead; download it from this forum.
Install it and it should fully install. After, launch the game and it should update and go through it's own processes. Sometimes the launcher can't connect the server but keep it up. I managed to activate my copy after a few tries. You should FINALLY stop getting the "launch error code 2" and be able to play your game.
source
I had this issue with AC... Made me so mad I deleted the game at the end, but this solution I never tried... No I'm sorry I was so rough..
Good Luck!
May 22, 2013 | Tom Clancys Ghost Recon Future Soldier for...
Script error
With the 0.8.0 Update, Adobe Flash must be installed independently on your computer for the launcher to successfully launch the game. Download Flash here: http://get.adobe.com/flashplayer/
This should minimize script errors in the launcher. If you guys have any further issues please send us a support ticket.
Installing the IE variant (which probably should be linked to explicitly instead of the general "get it" page) sorted out those script errors on Launcher.exe
It did not resolve the issues with the One-Click Application Reference launcher, of which I have been trying to fix it in a support ticket.
Nov 01, 2012 | Dell Computers & Internet
Camera launcher.exe does not work anymore
you probably need to uninstall
and re-install the canon program
and ,if you want to fix launcher.exe,There are 3 step to repair launcher.exe stopped working error
If you got launcher.exe stopped working error then there is a 94% chance that your computer has registry problems. To repair launcher.exe stopped working error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair launcher.exe stopped working error.
Nov 20, 2011 | Canon Digital Rebel XT / EOS 350D Body...
Accidentally deleted launcher.apk system wont run with out, how do I get a launcher back into? ?
HI, You can do 2 things on how to use the launcher.apk. First = you can try System Restore - click on start / orb - click on all programs - click on Accessories - click on System tools and look for System restore. - on System Restore, you will be given the recommended restore and choose another restore point. click on choose another restore point. - then choose the date when the launcher is still on your computer. then hit next. - the computer will reboot and then after you are on the desktop, the program should be back.
Second = you can uninstall and re install it again. - go to control panel. - choose programs and features - look for the program associated with it. click uninstall the then reinstall it again.
Hope this helps. Thanks for using Fixya.
Jul 19, 2011 | Computers & Internet
I installed easports cricket 2007 in windows7. but it's saying insert the currect CDROM when i click on icon for play.
its simple man,,since your game is not original u have to use the crack game launcher and it works,,
Nov 15, 2010 | EA Sports Cricket 07 for Windows
I had downloaded and installed halo-custom edition but when i tried to play it ask's please insert correct cd-rom and select ok to restart
Hi! Don't worry. That's normal. All you got to do is replace the existing game launcher with the working one, called crack. If you got the crack when downloaded it, then copy the (game name).exe to the installation location. if it's the working one, you will probably get the message that says that you already have that same file in the installation folder, but replace the existing one with the copyed one. And there you go. Double-click that new launcher to play the game. If you didn't got the crack when downloaded it, then download it. Go to btjunkie.com and type the game name, but add crack on the end(for example "Sims 3 crack"). Find the one who was most downloaded, and who people think it work's then click the down arrow to download it.
Jul 08, 2010 | Microsoft Video Game Consoles & Games
Game needs update, but the launcher doesn't work...?
download the patch straight off the ea website or of filefront.com
Jun 29, 2010 | Acclaim The Sims 3 World Adventures for...
I have a problem with the Empire at War part of my Gold Pack. The launcher says play but when ever I click the play button the launcher just disapers. When ever I instal the coruption expansion part of my...
there is a program named revo uninstaller that will help you remove the program and scan for any remaining information after the uninstall. I should clean up and reqgistry keys etc that might be messing with your uninstall/reinstall. Run this program and unstall the game with it. Then run an advanced scan and delete any items it finds. then reinstall your game. Hope this helps
http://www.revouninstaller.com/
Jun 29, 2009 | Computers & Internet
Phantom EFX Reel Deal Slots: Mystic Forest for Windows, Mac Logo
108 people viewed this question
Top Phantom EFX Video Game Consoles & Games Experts
James Wishart
Gary Tiedeman
Gary Tiedeman
Are you a Phantom EFX Video Game Console and Game Expert? Answer questions, earn points and help others
