Question about GE Profile Harmony DPGT750GC Gas Dryer
I have a problem with the dryer not heating up. According to error codes I replaced the blower motor which it said was not getting up to speed. That error went away. The next error said to check or replace the inlet thermistor, which I did. After replacing it, it still says check or replace inlet thermistor and then it appears no gas is flowing. I ran the dryer with the front panel off and see that there is nothing igniting and do not smell any gas, it stays dark and cold the entire time. Upon deeper inspection, underneath my gas valve unit I found a ceramic type white pin with a flat shaft encircled with what looks like a ceramic cracked black/grey spring around it lying underneath the gas unit like it might have fallen out of something. Can anyone identify or help? A few more parts and I'll be up to the cost of a new dryer.... Thank you
  • GE Master
  • 8,220 Answers
Main blower runs all of the time.
If you bypass tstat, meaning hot wired blower, does the blower cycle on and off by touching and removing red with fan?? If yes than obvious problem in tstat. I was leaning towards a bad relay but if you can make it work by passing tstat, there's you problem.
Jun 23, 2017 | Heating & Cooling
Whirlpool Duet Dryer, Drum doesn't turn
repairs should be performed by an authorized repair person. check the thermal fuse located on the blower housing. unplug the dryer and locate the thermal fuse and perform a continuity check. more than likely it is open, replace it.
Jun 03, 2017 | Dryers
Kenmore elite dryer. model 110.6708 or 09. check lint screen light is on. I have cleaned inlet/outlet/screen/front and back. unit will start but will not heat. if in the normal setting the f40 code wi
The F40 error code indicates a communication failure between the main machine control board and the motor control board for the blower motor on the dryer.
This can be caused by a loose wiring connection or a blown fuse.
Nov 22, 2012 | Dryers
Replaced control board on dryer still getting e61 code
The problem is not with the dryer as confirmed by the other identical dryer brought by the dealer. The problem is in the wiring of the receptacle where the dryer is being plugged in as characterized by error code E61 which means the control board is receiving a high voltage. The dryer operates both on 110VAC for the controls including the motor and 220VAC dedicated for the heating circuit. The receptacle must be configured according to the specifications of the dryer. Refer to the diagrams below and configure the receptacle according the plug that came with the dryer. Voltage across L1 and L2 is 220VAC, L1 and Neutral is 110VAC, L2 and Neutral is 110VAC.
Nov 17, 2012 | Frigidaire Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer not heating
inverter board may be bad. how long have you had the machine
May 07, 2010 | GE Profile Harmony DPGT750EC Electric...
My blower for heat, defrost etc. just quit and fuses are all good. What do I do next?
Unplug the power connector to the blower motor and check for power to the plug. If you have power replace the blower motor. If you do not have power check the speed resistor by switching between high and low speeds.
Also check the relay to make sure that it is functioning.
The speed resistor can be burned out in one speed. Normally they do not fail in more than one speed unless the plug to it is damaged. The plug for the resistor can be found on the firewall under the hood on the passenger side.
Replacing blower motor is easy, it books about .7 hours according to Mitchell so it should not be hard to replace. You will need no more than basic hand tools and a test light to figure this one out.
Feb 10, 2010 | 1990 Chevrolet Suburban
Blinking constantly troubleshooting ligt I revesed 115 v.pol.
This one is difficult to solve on line. I wish I could see the unit. First, check the diagnostic code chart on the inside of the blower compartment door. Constant blinking is the code for "normal no call for heat" or " normal call for heat". The diagnostic code chart will explain the difference according to the flashing speed. So this part may be ok. Second, disconnect your thermostat wires fron the furnace. If this turns off your blower you have either a bad or miswired thermostat, or a bad thermostat wire. If this doesn't narrow it down... then locate all of the wires coming from the blower motor.
If it is a "variable" speed motor the wires will be connected to the board by a module. Make sure the connector is plugged in properly. Check the dip switch settings to make sure you are not set for continuous fan.
If it has a "multiple" speed blower. Locate all of the wires coming from the motor. The two brown wires should be connected to the capacitor. The white wire should go to the neutral post on the board. The black wire will connect to the post marked "cool". Of the remaining wires... determine the speed by color according to the schematic. Place the desired heating speed wire on the post marked heat. The remaining wires MUST be connected to the posts labeled "park" or "spare". I believe that you may have mistakingly placed one of these remaining wires in the wrong location.
If none of this helps keep in mind..... just because the parts you changed are new, does NOT mean that they are good.
I hope this info helps you...
Good luck....
May 03, 2009 | Heating & Cooling
GE DPGT750 Gas Dryer runs but no heat
if your blower motor isn't getting up to speed it won't heat.check troubleshoot mode by holding my cycles and help at the same time for three seconds.may need a new blower motor
Mar 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Electric Dryer, Blower nt getting up to speed
You need to replace the blower motor. It says you are having temp problems because the blower is quitting and the heater is overheating.
Jun 01, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryer intermitantly drys.
I have replaced several blower motors on these units for that problem. If the board doesn't read the blower motor speed it won't turn the heater on.
May 15, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750GC Gas Dryer Logo
144 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
