Question about Olympus Cameras
Olympus Stylus 840 will not work after I erased all the pictures from the menu option. Menu appears but does not work, camera buzzes when power is turned on, zoon is jammed in extended position.
    President:
  • 2,712 Answers
You will probably have to update/upgrade the firmware. Go to the Olympus website and search for the latest firmware version of the camera and download to your PC. You can then install it into your phone.
You can first try a hard reset..Remove the batteries and SD card, wait a few minutes and replace with fresh batteries and see if this helps. you can also try tapping a side of the camera on the palm of your hand to try and dislodge the lens..
Hope that helps.
Posted on May 27, 2008
  • Swilin Sampson
    Swilin Sampson May 27, 2008
    Why an inappropriate rating? That is a negative rating and reserved for solutions that have absolutely nothing to do with the question. That is not the rating to choose just because the solution provided does not work.
    If it does not work after trying the solution, please post back on what steps you took, so we can troubleshoot further. Its not always possible to provide a solution on the very first response. Sometimes, a bit of to and fro dialogue is necessary.
    Please kindly revise the rating to at least HELPFUL and post back, if you have any further queries.
    Thank you in advance.
My memory card on the Stylus 410 digital is full. I have downloaded all photos and would like to erase the entire memory card. How?
Do you have a manual? Here is a link to the manual:
Olympus Stylus 410 Manual
You have to navigate through the menu to get to the ALL ERASE or FORMAT selection.
MODE MENU>>>CARD>>>CARD SETUP>>>ALL ERASE or FOMAT
When you turn the camera ON and press OK, you will get the "first menu". Press the right arrow to enter the Mode Menu. Use the arrow keys to navigate to the above item. Once on ALL ERASE or FORMAT, press OK.
Also, here is a quick start guide:
Olympus 410 Quick Start Guide
Scroll down to Section 5 for instructions.
You can save the manuals to your hard drive for future use once opened.
Thanks for using Fixya.
Jun 21, 2010 | Olympus Stylus 410 / ? 410 Digital Camera
How do I delete photos from my olympus digital camera?
You need to display the photos in the camera, and there must be a button on the back which enables you to erase pictures (look for a wastepaper basket icon). If you have downloaded all the pictures it is much better to reformat the card. This clears everything off the card and resets it. You need to go into the menu and search through it to find the format card option.
Jan 03, 2010 | Olympus Camedia Stylus 300 Digital Camera
Olympus Stylus 840 - lens won't open
you need to take it or send it for repair. There is nothing you can do yourself.
Olympus Stylus 840 Repair - Google Search
Mar 23, 2017 | Olympus Stylus 840 Digital Camera
Cannot erase all
Is the camera reading the card correctly? If you can see all of the photos in slideshow view, then it should be ok. You can go to Format instead of going to delete to delete all of the photos. Simply format the memory card. It is an option in the camera menu.
Sep 13, 2009 | Olympus Stylus 600 Digital Camera
Panorama Feature on Olympus Stylus 840
Forget the in-pano function and use a free stitching program off the internet. When shooting panoramas, you need to be in aperature priority or manual mode so as to keep the exposure consistant, especially going into the sun or away from it in your pictures. Although this is good practice, it is not needed for a few stitch programs as they average out all the exposures and make the entire pic uniform. This works pretty good in all but the most demanding exposure swings.
Jun 03, 2009 | Olympus Stylus 840 Digital Camera
Picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
Apr 23, 2009 | Olympus SP-500 UZ Digital Camera
Olympus 840, writers protect
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- Select Format - You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Feb 22, 2009 | Olympus Stylus 840 Digital Camera
Cant unlock a picture
If you want them to be permanently deleted you can format the memory card and this will clear the card of all data. If you just want these certain images deleted then you need to be in Playback mode - press the Menu button - go to Playback menu and press Ok - then choose the key option and turn it from ON to OFF. This will remove the lock and allow you to erase the selected image.
Dec 17, 2008 | Olympus Stylus 710 Digital Camera
Olympus Stylus 1030 sw...can I erase my entire card at once, or do I have to do them individually?
while camera is in playback, press the menu button. you will have the options of erase one or all. also you can format the card using the setup menu
Oct 13, 2008 | Olympus Cameras
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Cameras Logo
242 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
