EP3050 error code C004A
My used copier is giving me a C004A call for explaination.
Could you please tell me what this code means is wrong?
  • plumbdum May 27, 2008
    Thank you! Thank you! Yes, I've heard a fan squealing sometimes. Now no fan. I reset and tried again but after warmup went right back to code C004a. Can you tell me how to get to the fan and how much one costs? I really like this copier but we are on a limited budget.
  • 1,326 Answers
A C004a code is a error code with a fan in the copier. It is either not working or is making a noise. You may be able to hear the affected fan and try to lubracate it. There is a Trouble reset botton behind the cover of the display contrast knob. Its on the inside front cover above the fixing unit. Try to rest the code there first. Good Luck
Posted on May 27, 2008
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Have a Minolta CSPro 3050 with error code C004A. What does it mean
There is a fan located under the big glass section remove the glass an check the fan clean it or replace it.
Feb 01, 2012 | Minolta Office Equipment & Supplies
Error code C-004A
C004A Exposure fan problem
You will have to take this printer in for repair. Unless you can remedy yourself?
Aug 03, 2010 | Minolta DiALTA Di620 All-In-One Laser...
Please explain error code 000000
how the error code E000000-0000 is solved...give the solution
Apr 05, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I am getting a C004A error on a Minolta 4000 copier.
Optical section fan motor failure.Change the fan motor.To reset open and close the front door or press the service reset button(placed in the left up side).
Oct 07, 2009 | Minolta Office Equipment & Supplies
Giving code of "C004A". What does that mean?
May 04, 2009 | Minolta EP4000/5000 CS/PRO Copier
Sharp XE-A203
Hi.
The XE-A203 does not use error numbers. It should tell you what is wrong in words. The 202 does use numbers. An error 2 on a 202 model just means you pressed the wrong buttons.
Can you please check the model number on the machine and make sure it is a 203? Also, does it do it as soon as you turn the key to REG? What happens if you try the key in other modes?
Please try to give me as much info as you can, and we can try to sort it out.
Mark
Dec 07, 2008 | Casio Parts Cash Register PC Desktop
EP3050 error code C0040
A C0040 error code indicates a problem with the suction deck fan. It has nothing to do with the paper lift motors.
The fan is accessed by removing the rear cover of the copier. It is right in the center. These are readily available (p/n 9313-1310-61) although they are not cheap (around $200 retail).
Nov 15, 2008 | Minolta Office Equipment & Supplies
EP4000 C004A error
Open the back and check the fan that is probably suppose to **** air out of the optics area.
where the light comes on and scans across the glass
Sep 09, 2008 | Minolta EP4000/5000 CS/PRO Copier
311 people viewed this question
k24674
