I am trying to put music on to a memory card that already has music on it but it is telling me to remove the write protection on the card. How do I do that please
  • 7,733 Answers
Try this :
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
Posted on Oct 03, 2010
When I try to put music on my phone the computer says cannot copy song. The disk is write - protected. Remove the write - protection or use another disk. I could put music on my old phone. How do I remove...
If you were trying to put it on a memory card... Some memory cards have a little switch on them. Take it out, position the switch differently and try again. I hope it'll help. Thank you
Jan 15, 2011 | Computers & Internet
When i try to add music in to my card adapter pny SD 2 gb it says it has write protection and to take it off what do i do?..
To remove write protection
In your memory card adapter have a switch to on/off write protection.
pull this switch to down ,you can remove write protection of your memory card
thank you
Dec 23, 2010 | PNY 2GB microSD Memory Card
My Kodak V803 digital camera tells me memory card is protected. (Restart switch on memory card) i have tried to switch the camera of and on and remove the memory card but, the problem still exist. Please...
Look at the memory card itself. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 15, 2010 | Kodak V803 Digital Camera
When i try to put music on my microsd card it says that it is write protected how do i put music on?
insert the card, click on My Computer, dbl click on it and the drives attached should be visible right click the card and propteries comes up, un protect the disk from here.
Oct 10, 2010 | PNY 2GB microSD Memory Card
I have a 2gb micro sd card and I won't allow me to put music on it it tell me that it's write protected
Most SD memory cards have a little slide switch on the side of the card. This slide switch is a write protect switch, slide the switch to the read/write position.
Aug 23, 2010 | PNY 2GB microSD Memory Card
Write Protection
there is a lock feature on the card and see if you can move it the other direction if so try it then. that lock keeps from putting anything on card and taking anything off. If that does not work try to format it in the laptop first.
Jul 19, 2009 | SanDisk 4GB microSDHC Memory Card
Write protection
There is a small switch on the card. The Sandisk site has a photo of a larger card, smaller cards like the microSD must be inserted into the standard SD adapter.
Jul 16, 2009 | SanDisk 2GB microSD Memory Card
How do i remove write-protection from MemoryStickPRODuo from psp?
1. Remove memory stick from psp
2. Plug in usb cable and start usb connection
3. Insert memory stick and now you should be good
For some reason you might have to repeat these 3 steps everytime you want to access your memory stick
Hope this Helps
Apr 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Cannot Sync music files
okay... :)
1. the PC needs a CD-ROM with the cell phone's drivers to help interface the sync process.
2. you could transfer the files via bluetooth if both cell phone and computer have bluetooth components built in them.
3. if the PC tells you the memory card is write protected, look for a tiny little lock/unlock switch in the edge of the card to undo the "protect".
Hope this helps...
- J.
Feb 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
22 people viewed this question
jasbo
jasbo
