Question about Philips Televison & Video
I have a 32" lcd tv the power button comes on but only a black screen every once in a while it flickers like it wants to come on. Magnavox
  • Ray Soto
    Ray Soto Oct 03, 2010
    The green power button comes on . on my 32 inch magnavox (32mf23id/37) the set seems like
    it wants to come on but do's not, I was told it might be the power source.
  • Ray Soto
    I have a 32' lcd tv (32mf23id/37) the screen comes on and the piture looks good but it plays for a few seconds then it goes out . then it comes back on. does this continuaslly.
    It also keeps asking me for the pin to unlock
  • Philips Master
  • 5,138 Answers
Look for Bad Capacitors on the power supply board ,They will be vented,swollen or puffed up on top 2200uf 10v, 3300uf10v
Posted on Oct 03, 2010
    President:
  • 2,777 Answers
This is very bad indeed. It is one of two things, either a failed / failing video board in the TV and/or a failing power supply. Either way it is major hardware failure in the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will need to contact a local TV repair person in your area. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
Thanks, Tim
  • 10,515 Answers
This is not a good news at all. Their are at least 3 things that can be causing this however I will give you the favorite first and it isn't very good news
The backlight, this illuminates the pixels and is basically a very thin set of neon type tubes that are controlled by a board called the inverter.
The backlight can itself go faulty on these sets (even the US equivalent)causing this flickering, this isn't good news as the backlight is inside the LCD panel and is considered to be part of it replacing it would equate to the cost of the set new.....not an option
The inverter itself or its grounding could be faulty
Lastly and probably not the power board feed to the inverter is bad
If under warranty, get this fixed without ant charge. Few companies also have an extended warranties for these issues such as Toshiba, so it is also worth to call in and check the same before pulling out money from your pocket.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Oct 03, 2010
    Thanks for your response!!
    I did mention power supply -
    ' Lastly and probably not the power board feed to the inverter is bad '.
    Thanks!!
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Samsung ln40b550k1f screen flickers on and off
When the screen flickers on and off it usually comes from the power supply or backlight inverter being bad. For your TV, the backlight inverter and power supply unit are combined. As you can see in the picture attached it's the white part on the right side that has gone bad. You will need to replace that board. LN40B550K1F Samsung LCD TV Repair Guide
Mar 11, 2013 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
Magnavox 32'' LCD, Menu being displayed on the screen all the tim
Magnavox = Philips,for some sets there are software update's available.U can update te TV via USB.
Dec 08, 2009 | Televison & Video
Bush TV LCD 32 TV 005 HD
The black screen problem of your TV can be attributed to a backlight driver failure, busted backlight, or LCD driver failure.
The flickering indicates a failing backlight driver or a failing backlight. The screen should be totally black, without any glow, when either of them is not working. To verify, grab a torch and shine it on the screen. You will be able to see a faint display telling you that the backlight is busted or the backlight driver is faulty. If not, the LCD driver or the LCD panel itself is faulty, although it has a low probability due to the symptoms of the problem. The only way to fix the problem is replacement of the faulty part. You may need the service of a qualified technician to determine exactly which one is the root of the problem that needs replacement.
Dec 07, 2009 | Televison & Video
Televison & Video Logo
188 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
