Question about Delta Faucet Delta RP17453 Pull-Down Diverter Tub Spout
I have a Delta shower assembly with a pull-down diverter. When I engage the diverter for the shower, half the water seems to make up to the shower and the other half is forced through the back of the spout.
One of 2 things is happening. Either the o-ring is shot, or you have a hairline fracture of the plastic around the brass adapter. The o-ring is a #18, but if there's a crack in the plastic you'll need to replace the spout.
Posted on Dec 28, 2010
I have a delta tub shower faucet with a pull-out diverter. The model is "Delex" by Delta as stamped on the cover plates. I have not had any luck finding a replacement diverter. Neither Delta U.S...
take the details to a plumber supply shop ( where the tradies get their parts ) and discuss the problem with them
it is very possible that there are other makes that will fit in the holes to replace the delta unit
Mar 25, 2017 | Delta & Single Handle Shower Faucet
I have a garden tub w/o a shower attached. However, the fixture in the tub is the Delta pull down diverter (dont know why they would put that in a tub w/o a shower). Anyway, the diverter was pulled down...
If it was me... I would replace that spout...
the spout either is threaded on or it has a set screw on the bottom at the back that you loosen and then pull the spout off by pulling straight away from the wall...
Check and see if the spout has the hole for the set screw...if not then twist it counter clockwise and it will turn off...
then repalce the spout with a new one with out the diverter...
heatman101
Aug 05, 2010 | Delta Faucet Delta RP17453 Pull-Down...
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
Just installed a waterpic shower head, half the water comes out of faucet and half the shower head, any solutions?
If your tub spout has a knob that you lift to divert the water to the waterpic then replace it with a Delta service part #RP17453 pull down spout. It always sends 100% of the water to the shower head and will always snug tight to the wall.
May 24, 2010 | Water Pik & Wallmount Showerhead
My delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Sep 28, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Pull down shower diverted works, but allows bypass into tub
The diverter is supposed to leak a little bit, so it will disengage after you turn off the water. If the water is leaking out a little, that's normal. But if it is really leaking out you may need to replace the entire spout.
Aug 11, 2009 | Delta RP17453SS Standard Diverter Tub...
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
I just moved into a new place with Delta shower and tub. However, I have no idea how to divert the water to the showerhead. There is nothing to pull up (which is what i usually see in hotel tubs) to divert...
On the bottom of your tub faucet is a ringed part that is about a 1/2 wide. Turn the water on, grasp that firmly in your fingers, and pull it straight down. Your faucet should come on.
Sirwriter
May 15, 2009 | Delta Faucet #RP320 Divert Assembly
Delta diverted spout is stuck! Can't pull it down
You probably have lime deposits built up which won't allow you to pull it down anymore. Try spraying lime away on it and use an onld toothbrush and work it up in there. If this doesn't work, you can replace the spout with a generic one. The spout should just twist off. Sometimes they can be stubborn. Hopefully this helps.
Apr 03, 2009 | Delta Faucet #RP320 Divert Assembly
Delta Faucet Delta RP17453 Pull-Down Diverter Tub Spout Logo
784 people viewed this question
Top Delta Faucet Plumbing Experts
Steve Wood Plumbing...
Level 1 Expert
joeiaaz
Level 1 Expert
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
