Question about Teac P-A688 Turntable
Need assistance putting belt on turn table
You had replyed to my ad.. I recently moved my turntable that was stored in a box and the belt drive some how came off the turn table. You asked for a photo. so I will enclude one with this message that I'm sending to you. I would appreciate your help.
Thank you
P.S. If you could send a sketch as how the belt is loped over what ,that would be a great help also
  • 1 more comment
  • Allen May 27, 2008
    Looped.......lol
  • hamburgers Nov 13, 2008
    Same exact problem, someone please help me. Apparently there are absolutely no diagrams and HALF-WAY decent explanations on how to put the belt back on the turntable. Mine looks just like this.
  • Anonymous Dec 27, 2008
    i have the exact same problem mine is a brand new optimus turntable a the belt was off!!
    please someone tell me...no show me how to put the belt back on
    thank u
"Put the thing on the other thing. There you go."
- Everyone trying to explain this to me on the internet.
Posted on Nov 13, 2008
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
Can't get the darn to work
Remove the drive belt and see if the turntable spins, if it does the drive motor is faulty, if it doesn't then (if this is a new turntable) it's possibly got a locking device to hold the turn table steady during shipping.
Sep 12, 2008 | Sony PS-LX350H Turntable
Turntable is slow, especially noticable on 33 1/3 rpm
hi,
your turn table is a belt driven one. The speed turns down when the belt become expanded. you should replace the belt of your turn table. Also put some lubricant in its center shaft ( not from the top lubricate it slightly after removing the plater).
I have here added some video related to the replacement of belt for turntables.
Not the exact for your one,for all the belt driven turntable the procedure is the same
ok
Jan 17, 2011 | Crosley CR248 Turntable
It doesn't work. I have followed the instructions though i couldn't find the EG switch but the table doesn't turn when its plugged in turned on and started.
hi,
check whether you have inserted the belt or not. in new turn tables you hvave to set the belt in proper position before starting use. u have to make the belt engaged with the motor pulley.
I have added here a video which demonstrate the installing of belt in a turn table.
In your turntable you can see the belt under the plater when u remove the plater.
remember one thing after installation of belt before plugging it mains , do the following
1. lock the arm in the arm rest
2. rotate the plater 10 times with you finger (for resetting the start position
Then connect the power release the arm lock insert a record press start
If you need any further assistance from me , feel free to contact me through fixya
ok
Jan 17, 2011 | Sony PS-LX250H Turntable
Turntable belt is off.
Under the felt of the turning platter section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 16, 2010 | Teac GF-600 Turntable
Belt on recordplayer (turntable)
Look at websites that sell Dj equipment.......search for places that sell technics turntables for DJs......and make sure they also have belt driven models like stanton turntables......if they do, then they might have the belt that you need. if they don't then they can probably order it for you or know where you can get the belt from!
if you wind up getting a new turntable, go with a direct drive model....they don;t have that problem as there are no belts!
Dec 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Belt came off
the belt is at the button of the turn table.
lock down the turn table and turn the turn able upside down, unscrew the 4 screws and open the button plate. you may need to get a new belt. make sure it is the right size.(that may be a difficult, now a days).
Sep 08, 2008 | Numark ttUSB Turntable
The belt on my turn table came lose
01- Remove the rubber cushion.
02- Remove the Turntable Platter
03- Place your drive belt around the ridge inside the platter
(Make sure that it is not twisted)
04-Place your Turntable Platter back on the unit
05-rotate your platter until you can see a brass knob through one of the round holes in the turntable. (Your belt must be placed around the brass knob) The best way is to take a toothpick and carefully slide it under the drive belt and then pull it out enough that you can place it around the knob. I had the same problem and the above works. If you still have problems getting it back on contact me 352-377-1828......
May 03, 2008 | Teac P-A688 Turntable
Teac P-A688 Turntable Logo
1,617 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
