Question about Garden
I have a cub cadet mower newer 19 horse it has a plastic oil dipstick it broke and fell in is it a problem or do I need to pull the side and fly wheel
  • 26 Answers
Hi dpelzer--
That piece must come out! Do not run your engine before you are sure the dipstick has been removed. Try to avoid moving the mower while that piece is in there, as any bump can dislodge it from where it may have hopefully fallen: straight down.
Before you move anything, use a flashlight and look into the dipstick port--the hole that you check and fill the engine's oil from. Can you see the remains of the stick?
If you can, leave everything alone and go to your hardware store and buy a "parts grabber," it looks like a long spring and has tiny steel 'fingers' that will open and close when you push a plunger on one end. Carefully, slowly, try to grab that dipstick. Take your time and use extra care so you don't knock that dipstick into the crankcase.
If you succeed in removing the stick, inspect it carefully to be sure none of it has broken off into the crankcase of your mower's engine. Check the dipstick in its entirety, from the handle down, to be sure it is intact.
If you suspect any parts have remained in the crank, or if you cannot remove the dipstick from the oil fill/check hole, your last option is to dissamble the engine to remove its contaminants. This can be a costly, time consuming job.
--Hope this helps
Posted on Oct 08, 2010
Cub cadet ltx1040 oil light on
Thomas, the oil light is on as a result of a signal from a pressure transducer that is seeing low oil pressure being developed within the engine. Unless the transducer is bad, it is telling you it is low on oil. A simple pulling of the oil dipstick while cold should show you a low oil level in the crankcase.
Oct 04, 2015 | Cub Cadet Garden
What would cause 19 horse kohler in cub cadet to belch white smoke
answered already look at charles beach answers mower belched white smoke
Sep 02, 2014 | Cub Cadet 42 in. 19 HP Kohler Courage...
What caused 19 horse Kohler to belch white smoke
white smoke fuel blue black white smoke oil over fill oil will cause it getting to much fuel will cause it check carberator check oil
Sep 02, 2014 | Cub Cadet Garden
Oil drain location on cub cadet rt65
How old is it? Lots of newer small engines don't have a drain plug. You tilt it on its side and let the oil run out the oil filler hole after removing the dip stick. I put a piece of plastic shopping bag over the gas tank hole and put gas cap back on to help keep gas from coming out. Good luck.
Jul 26, 2014 | Cub Cadet RT65E - RT65E 18" 208cc Dual...
Self propelled cadet mower locked up how to unlock
Check engine oil level first for proper level.If it has oil in it PULL SPARK PLUG WIRE OFF SPARK PLUG IF MORE THAN A SINGLE CYLINDER PULL ALL PLUG WIRES OFF. Put unit on its side and grab the blade and see if you can move it in either direction or if the engine is locked up.
Jun 11, 2014 | Cub Cadet Lawn Mower Deck Drive Belt...
I changed the oil on my cub cadet lt1042, the oil light is still on
THE AIR FILTER SHOULD MAKE NO DIFFERENCE, THE LIGHT MAY BE AN OIL PRESSURE LIGHT NOT LEVEL LIGHT.
May 02, 2012 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
How do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
