Question about Refrigerators
Ice maker doesn't make ice anymore - Refrigerators
  • 5 more comments
  • Anonymous May 28, 2008
    emptied ice maker will not make more. checked gears and fill tube still no ice. whirlpool mdl en2shaxqi0
  • Anonymous Dec 07, 2008
    Same model, same problem. Water on door works ok.
  • reap70 Dec 23, 2008
    My ice maker does not make ice. No water in the line. Water dispenses, but slowly. I switched the plugs for the ice maker and water dispenser and when I pushed in the water dispencer, water travelled up to the ice maker. Also, we had a storm a while back where a tree pulled the main power line out of the house and we lost power a few days. Ice maker worked for about a week, then quit again. Is this a wiring problem or a freezing up problem? When the power went out, maybe something thawed out and caused it to work, but I need to isolate where the problem is.
  • Bob Moran Dec 27, 2008
    My tray fills Ok but when frozen the whimpy little motor won't bend the tray enough to dump and reset so it times out and resets unfilled. I can help it complete the twist by hand and it works fine. Maytag out twice and installed a room temperature  tray and would not wait for a cold test.  Of course as soon as it was cold enough it failed again.  I have three complete new icemakers and none work.  I may go Tim Taylor 'More Power' on it and try jumping up the motor voltage.
  • dbcrump Jan 11, 2009
    I emptied my ice tray, it was full and it has not made one piece of ice since?
  • shawk50 Jan 18, 2009
    No water going ingo ice maker, therefore, no ice being made. Water is going through lines into refrigerator
  • big sexxy Jan 28, 2009
    my ice maker tube is frozen with water and it wont make ice and water dispenser is running slow
Here is a solution I came up with. Pour water into the ice tray by hand and you have ice! Just a little humor for you all. I still haven't fixed mine.
Posted on Mar 18, 2009
I had to purchase a new "Valve" for the refrigerator. Once that was installed, the ice maker worked great. I also "defrosted" my freezer for 24 hours just in case the "pipes" were frozen.
MY Samsung rs2577sw side by side refrigerator doesn't make ice. The water supply is fine. I can still fill my water glass. My name is Mike and my email address is maubart@yahoo.com
Posted on Jan 05, 2009
Whirlpool gss26c5xyy ice maker not making ice, but will dispense ice and also will dispense water.
Andrea, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
Good luck
Jul 08, 2017 | Whirlpool Refrigerators
Ice maker doesn't make ice. It seems to not being able to rotate the ice tray to dump the ice.
this may be a bad heater in bottom of ice maker . if so replace the ice mker .. but do ck the tempts ..freezer must be 15 de or lower for ice maker to work properly .. hope this helps mm .. feed back pls ..
Jul 10, 2011 | LG LMX28988
Our automatic ice maker will not quit dripping in the freezer. It keeps clogging the ice maker with icicles and large blocks of ice. Essentially, it keeps "freezing over." We have defrosted it...
if it keeps filling and overflowing you have a bad water valve on the back of the fridge.the part number is WR57X10027 and the valve is around 75 dollars.first thing lift the arm or shut off the ice maker so it won't leak anymore,you're missing a few letters off of the model number so when you call your parts store give them the full model number,open the fridge door,look up on the right hand side wall up near the ceiling and give them the model number to make sure you get the correct valve,shut off the water supply to the fridge,then have the new valve next to the old valve when you remove a water line from the old valve just connect it to the new valve,do this until everything is changed out and the new valve is in place,turn on the water supply and you can check the ice maker to make sure it doesn't overflow.you can manually start the ice maker by grabbing the plastic arms of the ice maker and pull them forwards slowly until the arms start to advance on their own,you'll hear the water valve fill the ice maker and then you can watch it fill to see if the water is filling it correctly and i'm sure you'll be fine with the new water valve installed
Jun 05, 2011 | GE Monogram ZDI15C Automatic Icemaker
My kenmore 52672200 ice maker does not make ice anymore
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Dec 25, 2010 | Kenmore 52672 / 52674 / 52679 Side by Side...
My ice maker doesn't work anymore
heatman101
Oct 10, 2010 | KitchenAid Superba Architect KSCS25INSS...
Doesn bring water to ice maker
If you have water at the door, the most likely problem is that the metal bar that shuts the ice maker off has been moved to the off position. Check to see if the metal bar is in the up or down position. If it is up, move it down and vice versa and give it an hour to see if it begins making ice again.
May 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped working. water still dispenses but no ice is forming anymore. can you help?
heatman101
ghhdg
Feb 10, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Refrigerators Logo
572 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
