Question about LG Televison & Video
I have a LG Flatron 21" Televison Model NO RF-21FC80E. We used to adjust its position to our watching convinience regularly but from past few days its sound and its picture goes off as if it was placed in a switched off mode. It works when suddenly and goes off again and sometimes it works for hours as if there is no problem. Our TV goes off generally during adjusting the adjustment. Kindly help me out.
tvtechnician
  • 105 Answers
SOURCE: samsung lcd tv
that is deafinatly a fault. take it back to the store asap if you can. what the tv needs to be fixed is first replace the main and power board and if problem persist the lcd panel will need to be replaced.
Posted on Nov 07, 2007
djnick989
  • 1067 Answers
SOURCE: Problem with sound and picture
sond slike bad tv almost is your power strip grounded well bets one is monster clean power clean up older homes power so dirty in usa cuses flat screens to die out elery if u have up down voltage in house also cheak hd antenna whos your cable from charter or dish
Posted on Jan 06, 2008
  • 33 Answers
SOURCE: Fuzzy, Grainy Pictures
This camera is a perfect one to show the problem with the tiny sensors in the typical point and shoot. From the same sensor size that previously gave 2 or 3 megapixels, Canon now extracts 7.something. In order to do that, they have to turn the gain up so that each pixel actually puts out a signal to be recorded. The natural outcome of that is noise. In this camera, Canon includes heavy noise reduction software that softens the image in order to reduce noise at the various ISO settings above the minimum one, but the result is still a mix of noisy and soft or fuzzy images.
However, the noise should be well controlled at the low end of the ISO settings.
I suspect you have somehow gotten the ISO setting set up higher than the lowest one. Use the four-way controller to access the ISO and set it to the lowest (80) value. This should give you noise free shots.
As an additional suggestion, read the concise review of this camera at Dpreview, the link for which I've provided.
http://www.dpreview.com/reviews/CanonSD800is/
If you have any questions, please let me know before giving this answer a rating and I will provide it. Thanks.
Posted on Feb 06, 2008
SOURCE: Auto adjustment.
Try this one:
the is not the same problem. But the cause is exactly the same
http://www.fixya.com/support/t117851-menu_screen_appears_all_time_flashes
Regards
Posted on Feb 10, 2008
Highdefjeff
  • 124 Answers
SOURCE: vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Posted on Apr 24, 2008
How to change day and date
Oh-Kay Yogesh Thapa,
48 hours is more than ample time allowed for you to disclose
any watch make or model...
Sans any such information...
a generic answer is the best we can do...
In MOST cases... You can adjust your day/date
by finding the "middle" position of your stem:
Full position is all the way (gently) extended
WHERE YOU CAN SET TIME
Push the stem half way in and roll the
stem in that position...
The DATE should start advancing...
Instructions for my HEUER Monaco
(real one) has no such mechanism.
On that watch you must spin the hours "PAST MIDNIGHT" repeatedly (from before 9pm past 1 am... and back).
On the Concord Impressario... Date is easy but
month & day
(woooh)... I ought to get out the instructions...
The old TIMEX (chronograph)... definitely time for
(unmanly art of reading) the instruction book.
Hope this helps
Carnac the Magnificent
Mar 24, 2017 | Watches
MY MONITOR MODEL IS LG FLATRON T705SH I CANNOT ADJUST MY SCREEN RESOLUTION I WANT TO KNOW THE VALUES SUCH AS POSITION: SIZE: SHAPE: PLEASE HELP ME OUT SIR AS SOON AS POSSIBLE
Your monitor supports a maximum resolution of 1280 x 1024. If windows fails to give you the option of changing to this resolution and those below it then please follow these suggestions:
Update your video card drivers, if you don't know the manufacturer of your video card try windows update.
Install the latest drivers for your monitor as well.
Your monitors driver click HERE
May 04, 2011 | LG Flatron F700B 17" CRT Monitor
My monitor is LG FLATRON E700SH out of shape it is not getting adjusted can u please give me the perfect shape specifications
I have a problem of setting screen onto moniter ... So just suggest me what is Screen Position , Shape Size to me
Oct 08, 2010 | LG Flatron F700B 17" CRT Monitor
I have a LG Flatron 22", LCD monitor, model is W22345. dilemma: after sleeping the computer for the night, as I have been doing for the past 8 months that the computer and monitor has been in my owne
Check the video cable,replace them, and if didnt work, try to reset the config stored on the settings of the monitor (usually by menu).
Some electronic problems could do the same simptom. check the manual for hints.
Good luck
May 23, 2009 | LG 22" FLATRON LCD Monitor
LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Jan 15, 2009 | Computers & Internet
Tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Jul 14, 2008 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Vertical muliticolor lines
The output freq of the vcr is sitting to close to an rf signal from a digi broadcast i guess,cross modulaion is the term.the rf can be moved away in freq to another bit of band width or if not using rf connection it can be switched off rf output altogether.find online vcr manual and find rf change section
Jan 07, 2018 | JVC PD-42V31 42 in. Plasma Television
Televison & Video Logo
109 people viewed this question
Computer Repairing
Computer Repairing
