Question about Eagle Air Tools & Compressors
I have an Eagle 3 cylinder single stage compressor that i've had for years and it has performed flawlessly. Lately i've noticed that as it is building pressure the motor drags down to a lowly putt putt and then picks up again. My shop lights down dim or anything. Also when it is building up pressure and nearing the cut out pressure which is 120lbs it will slow down @ 100Psi and will struggle for the last 20lbs. Do I have an electrical motor issue or a cylinder issue? I would assume electrical..thanks..
    Scholar:
  • 146 Answers
I think you are correct with the motor problem but without the model number it hard to know what set up you have.
Eagle Compressors is now located in Belmont Mississippi so you can still get replacement parts for most of the Eagle compressors.
Thanks
Posted on Oct 04, 2010
What grade of oil do air compessors use
iso 32 // 30wt. compressor oil, or no additive mineral oil, never use automotive oil in a air compressor
May 06, 2014 | Eagle C5160v1 - Single Stage - 5hp 60...
VP10 Pump,air Compressor,single Stage,3 Hp 5FTU5
3 inch pulley with a 3600 rpm motor. 6 inch pulley with 1800 rpm motor.
Nov 04, 2013 | Champion VP10 Pump,air Compressor,single...
Motor heats up
It could have a bad motor start relay.
Jul 27, 2012 | Eagle C5160v1 - Single Stage - 5hp 60...
Locate pressure relief valve on c5160v1 eagle compressor
it is located on the 4 port manifold on the bottom of the pressure switch
Jul 05, 2012 | Eagle C5160v1 - Single Stage - 5hp 60...
Compressor will not turn on
some air compressors have a lever on the pressure switch to turn off unit, check the contacts in the pressure switch, I have found mashed insects between the contacts on some I've repaired
Aug 16, 2010 | Campbell Hausfeld Single Stage Air...
Campbell Hausfeld compressor has trouble starting
Sounds like your unloader valve is not releasing pressure in the line to the compressor. When it shuts off after filling up if you do not here the psssht that they make when it is releasing the air in the line to the pump. then the line is still full of pressure which makes it hard for the motor to start. Check your unloader valve.
Mar 30, 2009 | Campbell Hausfeld Single Stage Air...
Unloader valve leaks on my compressor leaks air constant and I think that it must need replacing, does it? just old or what?
THE VALVE COULD BE BAD BUT IT MORE LIKELY THE CHECK VALVE IN THE TANK ISNT CLOSING. DRAIN PRESSURE AND REMOVE CHECK VALVE FROM THE TANK AND INSPECT.
Mar 08, 2009 | Campbell Hausfeld Single Stage Air...
With compressor running the relief line blows off
check that the non return valve is not stuck closed
hope this helps ian
Feb 24, 2009 | Campbell Hausfeld Single Stage Air...
Air Tools & Compressors Logo
334 people viewed this question
Top Eagle Air Tools & Compressors Experts
John Trevino
Bill Boyd
Steve Pack
Steve Pack
Are you an Eagle Air Tool and Compressor Expert? Answer questions, earn points and help others
