Question about DCS WO-130 Stainless Steel Electric Single Oven
The display - clock and the oven temp. readout on my DCS wall oven sometimes fades away to nothing and remains that way for days. Other times it may be dimly visible; usually after the oven has been heated and used and then turned off.
    Sergeant:
    Champion:
  • 351 Answers
The display or readout need to replace
Posted on Oct 03, 2010
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
We clean are double wall oven and I can,t reset the clock.
Hi williamk77,
Your post "reset the clock" may refer to three (3) clocks in your Dacor ECS230. The first is the "Setting the Time of Day" which could be performed by pressing on the "CLOCK" touchpad. The time of day will falsh. "AM" or "PM" will be displayed and "TIME" will flash in the display. Thereafter, press the touchpad "+" or "-" until the correct time of the day is displayed and release touchpad.
The second is the "Using the Minute Timer" which is better explained at the user's manual page 6. Below is a snapshot of that part of that page.09d8cbe.jpg
and the third is "Timed/Delayed Timed Cooking" likewise better explained at the user's manual (p.9). Should the manual be not readily available, it may be downloaded from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 27, 2008 | Dacor ECS230 Epicure Electric Double Oven
Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
Sep 28, 2015 | Smeg Ovens
My clock display is faded, oven works, no temp readings
the e o c ( the clock) is at fault . and the diag is correct . most parts today only cary 3o days .. hope the hepled . mm
Jul 13, 2010 | Whirlpool RBD305PD Electric Double Oven
Temp/clock display faded
its the display that is going out on the ovenlike everything else things just fad away. Actually I have had LED meter displays do the same thing.
Dec 23, 2008 | Thermador SC302T Electric Double Oven
Temp/clock display faided
its the display theat is fading away. I've haad meter's do the same thing after awhile and there's nothing you or I can do. Thanks for using Fixya
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS Fisher@Paykel 1-888-281-5698 new Zealand.
Oct 03, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS elect wall oven LCD display
Had the same display issue with my DCS WOS-230. The display was fading and made it very hard to read clock and temp setting. Called DCS/Fisher Paykal and was told I need the Control system kit for $335.00 to fix the issue. After reading the input on this issue on this site I pushed them to sell me just the DCS EOC 211696 double display module 100-01095-00. Install took 10 minutes and everything works great. Thanks all for laying the groundwork as DCS will really push hard to sell you the more expensive kit that you do not need.
Jul 17, 2008 | DCS WO-130 Stainless Steel Electric Single...
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
DCS WO-130 Stainless Steel Electric Single Oven Logo
647 people viewed this question
Top DCS Ovens Experts
ashburton
Joyce Nokleby
ray gallant
Are you a DCS Oven Expert? Answer questions, earn points and help others
