Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
How come I cant install the drivers for the video card. Also when I set it to cable and hit next it jumps to antenna. How can I fix that problem? I have the installatioon disk but it wont load the drivers. I've copied the drivers on to my hard drive but they still won't load.
  • Philips Master
  • 7,733 Answers
Try -----> HERE.
Post back!
Posted on Oct 03, 2010
Hello, i got my new graphic card (ASUS EAH6850 Direct CU 1GB/D5) and i placed it in my pc and got all cables on the right place. the screen works, does everything but resolution isnt good and i cant...
First if you haven't done so, you need to install all the drivers that came with the new video card. when you first install a video card only some bare bones basic drivers are used to access and make the video card function. Those drivers will make the video seem jumpy and have low resolution.
Once that is completed and your computer is restarted, you might need to change your resolution. to do that, here is the easiest way:
Find a spot of your computer desktop without icons and right click. there should be a menu that pops up. In windows xp you need to select the menu item that says properties and click the tabs of the new window you have up until you see resolution. In windows 7 it says screen resoultion. Change the slider bar until you find it right one for you.
If you set it to high not to worry, don't hit anything for 15 seconds after you change it and will revert automatically.
Apr 21, 2011 | Computers & Internet
I am running on a Dell XPS and my dazzle dvd recorder wont work.
Hi and Welcome to fixya!
I suggest to you to double click on Instant DVD Recorder Icon and choose go directly to Advance mode. Click next. On step number 1 click the pull down arrow and choose dazzle DVC 100. Click on options and choose video input. If your cable connection is the yellow red and white cable then choose Video composite, If S-video cable then choose Video S-video. If you have a VHS player click VHS input and click okay.
Next when everything is done turn your camcorder,vhs,vcr and then hit the play button.
That is the time that the video image is showing to the preview screen of the computer. Still not showing disconnect the dazzle device and place to another usb port.
If your dazzle device is not showing under step number one, you need to download and install the driver to Pinnacle Website.
Dec 31, 2009 | Pinnacle Dazzle DVD Recorder
My tv just stopped getting antenna reception today.
It is not possible clear picture use indoor antenna it is use cable tv then get a lot of channel enjoy
Sep 24, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
AMD Motherboard with, on board video card has voltage short no video available on monitor. I would like to disable and add a AGP card.
When the Computer is off install the AGP card and put it together next start the computer when it starts up hit Del key before it boots up go into bios go to devices and disable onboard video, then hit F10 say yes to save changes and reboot it will then detect the card and will ask for drivers for the card. Be sure you read the directions for the video card You may have to install the drivers first, since you did not mention the card brand names and what mother board you have. Asus has many mother boards.
Jul 09, 2009 | Computers & Internet
AMD Computer Reviews - Phenom 9850 Quad Core Processor - HD985ZXAGHBOX with biostar n750 motherboard sli ready nvidia 9500gt graphics card after putting vista on worked great, until i installed the...
reboot the computer and press F8, start in safe mode and unistall the graphics drivers using "device manager" reboot the pc and do a microsoft uptade to install the drivers for you
hope this helps
regards
Nov 19, 2008 | AMD Computers & Internet
SAVING SETTINGS
When you hit Save or Apply in the Control Panel, the driver remembers the settings. You did that right.
The problem might be when the computer restarts, that the graphics card doesn't correctly check for the SVIDEO output, OR your monitor is missing a resistor (some Sony and Panasonic) on the Chroma output that tells the video BIOS that there is actually something attached (DC-coupled). The latest NVIDIA drivers can detect AC-coupled monitors on the latest GPUs, but since the VBIOS sets the environment, the driver may not check again.
It is possible that uninstalling the video driver and installing a newer one might solve the problem
Aug 04, 2008 | Nvidia GeForce 7200 Graphic Card
Emachines T2482
Could be a video card failure or a cable problem. This could also happen because the motherboard failed if you have integrated video. Unfortunately your going to have a tech onsite to repair the issue. That is, unless you want to install your own video card which would probably fix the issue.
Jul 08, 2008 | E-Machines eMachines Refurbished EMA...
Screen problem with the hp pavillion zv6000 notebook pc
Sometimes intemittant video can be caused by a couple differnet things on a portable system.
1. Bad ground. Some LCD are grounded to the chassis through the hinges. If the screws for the hinges become loose, the ground becomes intermittant. So tighten any screws for the LCD hinges.
2. Sometimes the LCD video cable connection to the video card becomes loose from heat expansion. So see if you can find the service manual on the HP web site, and see how to reseat the video cable (should be listed under the LCD install/removal)
3. If neither of those resolve, then you may have a problem with the LCD itself or the cable that goes to the video card as hte cable goes thru the hinge assembly.
May 14, 2008 | Gateway FPD2275W LCD Monitor
Screen size change itself
I think the problem is not your monitor itself . the real problem is your video card, maybe the video card is damage or the video card driver is corrupted. Try to re install the video card driver. In the run type DEVMGMT.MSC hit enter . If the device manager windows open select and double click the DISPLAY ADAPTER delete the video display model and click ACTION, SCAN HARDWARE CHANGES the windows automatic search for the driver and install it but sometime you need to insert the cd driver. If you dont have a video driver with you look in the internet for the model of your video card.
May 11, 2008 | ViewSonic E70f 17" CRT Monitor
Monitor doesn't stay on.
Your problem seems to point to your video card. Your video card needs a driver to function. Odds are good that you need to install a video card. Avoid using the built-in Windows driver. A new video card has a CD with it. Use that. With your driver installed, configure your display settings. The Display applet on the Control Panel is your next step. The Display applet provides a convenient central location for all of your display settings. Go there and make your setting using the tabs.
You can crash Windows and force a reinstall simply by installing a new video card and not uninstalling the old card's drivers. Always uninstall the old card's drivers before you install drivers for a new card.
Mar 17, 2008 | Computers & Internet
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
