Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Right side speaker is not working - Creative Labs Sound Blaster Live! 5.1 Sound Card
    Problem Solver:
  • 5 Answers
Most likely, ensure the balance is set correctly to the middle.
If this is set correctly, try swapping the speakers. If the bad speaker (the right side one) fails to play when plugged into the left side cable, then the speaker is faulty. However if the bad speaker now plays but the good one doesn't, its an issue with either the cable or the sound card. Replace them in that order.
Hope this helps, Benji
Posted on Oct 03, 2010
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
KA-994 Model Right speaker channel not working. How do I fix it?
Hello
Check the speaker of the right side first for damage. Connect it to left side and listen whether it works or not. If it works with left side, make sure that the audio output section circuit to the left side inside your amp has damaged and should be replaced. If the speker does not works with connecting it to the right side, make sure that the speaker has damaged. OK.
Dec 23, 2011 | Audio Players & Recorders
Sbs 2.1 370 speaker problem is only when we coonect speker to right side. Left side not working
i have this problem too,sbs 2.1 370 speaker problem is only when we coonect speker to right side. Left side not working
Nov 21, 2010 | Creative Labs SBS 370 Computer Speakers
The right speakers logitech Z 5500 do not work
try buying a new optical cable or change some settings on your tv.
Feb 04, 2010 | Logitech Z-5500 Computer Speakers
No output from right side speaker jack
audio board located inside the mainboard console to the right trace your speakers wire to bd, disconnect the three leads, 3 phillips screws, and examine bd for burns. If yes, ebay the board id for a replacement.
Apr 24, 2009 | Dell W4201C 42 in. Plasma HDTV
Right side speaker barely works
Likely the control is old and dirty.  It is known as a rheostat on older units and often a little contact cleaner on it will work.  A simple thing to try that might work is to rotate the knob back and forth, left to right, each time going to full stop.  do this several, several times.  See if this makes things better.  Of course, the assumption I am making is that the right speaker is operating normally.  If you switch out the left speaker for the right, and the problem persists, on the same side, it is the receiver.  If the problem now appears on the left side, it is a speaker issue and not the receiver.  Good luck and let us know how it goes.
Jan 02, 2009 | Audio Players & Recorders
New alpine speakers just stopped working on one side of my car and don't know what to do
Just check the wiring connection from receiver to your speaker,try to interchanges the left and right or to one side and to other side,so we know that the speaker is the problem .If happens still only one side is working even you interchange,then the problem is the speaker. If happens the speaker from left to right is working then the right to left is not works then the problem is the one side of the amplifier section is defected maybe the IC chip is busted or just loose,crack or cold solder joint.If cold solder only then reworks the solder joints in amplifier section.Then if the speaker is defected just reworks the solder connection of the speaker only .If still not working even you resolder the speaker then thats is the time you replaced the speaker...
Hope this may help;
Regards,
VOTIT
DON'T FORGE TO RATE;
Sep 01, 2008 | Audio Players & Recorders
Speaker Problems
Can you swap speakers and see if the left working speaker works when plugged into the right output?
If it does, then your right speaker is bad or the right speaker cable/plug may be bad.
If the working left speaker doesn't work on the right output, then I would suspect a problem in the right channel audio amplifier.
Please let me know if I can be of further assistance to you.
- Jim
Feb 29, 2008 | Emerson MS3100 3-Disc CD Changer
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
103 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
