Question about ViewSonic NextVision N1700w (Black, Metallic) 17" LCD Monitor
My ViewSonic N1700w will come on just fine, and within seconds go blank. I know it's not the input, I have doubled it with my laptop, and the laptop graphics are fine when the ViewSonic goes blank. Is it possible to be the inverter board, or maybe is it something simpler than that? Do the caps on the output connection(s) to the CCFL bulbs go bad like the older models? They are not electrolytic caps, they are high voltage film capacitors. Ok, so just wondering if this is a problem that has been consistant with this type or model. Thanks-Joe
  • Joe Huber Oct 03, 2010
    Thanks, that's what I had thought all along. Guess I just needed a confirming opinion as well. Too bad they don't sell the inverter board (lcd doesn't either). Guess I'll try looking for repair schematics and parts. Thanks again!
  • Joe Huber Mar 31, 2014
    Follow up on my previous situation. I have since put my display on a machine running Windows 7 and it comes up just fine. I have done nothing to this display since 1st posting. Just have taken it from what was before a Windows Vista, and put it on a Windows 7.
  • 4,924 Answers
You have to change the inverter ..cause if it opens normal and goes blank after a few seconds..this is the only cause..This is a sure thing ..Change the inverter board and will be fine..
Posted on Oct 03, 2010
What do i do when it comes on and shows analog then goes blank ?
Are you using the analog input or another? If using another input instead, then press the 2 key. It will switch to another input as the source signal. If you still experience trouble, please contact ViewSonic technical support for assistance.
May 03, 2014 | ViewSonic VG1930WM LCD Monitor
How do I re-program my viewsonic remote?
This is the instruction for my N2750/3250 remote.
Resetting Remote
• To reset remote and access default settings press and hold desire device button for roughly six seconds and enter three digit reset code 000.
• Replace batteries if remote control keys are not functioning properly, this is a normal behavior that indicates batteries are low.
N2750 IS 008
N1700W
001
N1300
002
N1500
003
N1750W
004
N2010
005
N2010-E
006
N2700W
007
N2750W
008
N3020W
009
N3200W
010
N3200W-E
011
VPW4255
012
VPW5500
012
N2000
014
N3000W
015
Email me if you want me to send you the full PDF from VIEWSONIC, budmrtn@aol.com
Aug 31, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
My viewsonic vx924(vs10162) start very good when i turn on my pc then after 2 or 3 seconds goes white but i turn it off and on again and it works just fine i try it with other pc and does the same what can...
The picture board on your monitor is bad, since the power led or button is on and all connection are correct and goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jul 04, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Hello, I have a ViewSonic N1700w. I have hooked it up correctly(all drivers downloaded, proper connections, etc.). When I turn it on the power led blinks until there is video or graphics to display. When...
it sounds like the inverter was defective, the monitor will be fine for few seconds then go off but power light still stay on with Green. You can contact with manufacturer for repair service if it still under warranty.
Mar 22, 2010 | Computers & Internet
How do you connect a viewsonic vg15ob mo niter into my labtop
Chances are you laptop has a vga input (looks like a blue trapazoid with lots of holes). Most monitor come with a vga cable. If this is the case you are good to go. If you dont have a cable for the monitor, you need to look on the back to identify the type of input(s) you have (DVI,VGA, or RCA). Then go to your local electronics store and tell the guy/girl you need a blank (monitor input TO blank (Laptop output) and you should be in business.
Let me know if this helps.
Jer
Jan 17, 2010 | ViewSonic VG150B 15" LCD Monitor
Remote control UBRC-120 for LCD ViewSonic N3751W is not responding to commands
I have URC-100 which is similar to your remote, try these codes: Please post back waht you find.
N1700W
001
N1300
002
N1500
003
N1750W
004
N2010
005
N2010-E
006
N2700W
007
N2750W
008
N3020W
009
N3200W
010
N3200W-E
011
VPW4255
012
VPW5500
012
N2000
014
N3000W
015
Nov 12, 2009 | ViewSonic N4251w 42 in. LCD Television
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Picture goes out after 1 second, audio is fine
the problem is not the mian board but the DC to DC inverters that drive the lamps behind the panels some manufactures make them available seperate from the panel but most are a part of the panel. so the whole panel may have to be replaced.
Nov 02, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic NextVision N1700w (Black, Metallic) 17" LCD Monitor Logo
55 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
