Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
Freezer defrosting our 3 year of freezer is defrosting: causing all the food to become soft and lose it frozen state. also, there are ice chunks at the bottom shelf of the freezer and the last 1/3 of the door does not close tightly.
  • 725 Answers
Need to defost the whole freezer get the door to close correctly...
Posted on May 27, 2008
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost...
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
Jan 29, 2014 | Freezers
Not freezing enough
You might have ice building up on your evaporator coil. That ice serves as an insulator and prevents the internal freezer temps from going down to design parameters. The ice buildup is caused by the defrost mechanism not working - check the timer or the defrost heating element.
Jan 07, 2014 | Summit 12.6 Cu. Ft. Frost Free...
Food is frozen, ice cream is soft
Thanks for choosing FixYa and welcome to the site. Gary, I have seen this a lot myself and I have asked many people about this occurrence. The ice cream usually goes soft when the freezer goes into defrost mode. I would say this is what happened here. It always puzzled me and I finally asked around. I was confused because sometimes it was froze and sometimes it was soft. I hope this helps you out.
Apr 19, 2011 | Amana Freezers
Everything in our freezer is frozen solid except for the ice cream which is soft and mushy, the freezer is only about 3-4 years old and we checked and it is turned up to the coldest setting, any ideas what...
If this is a self defrosting model make sure that you don't have frost build up on the back wall of the freezer causing the air not to circulate like it should. If you do have frost build up other items will eventually start thawing as well. If this is the case you have a defrost problem.
If this is not a self defrosting model then make sure it does not need defrosting.
You normally will notice ice cream being soft before you notice other things thawing.
Also make sure the door is shutting good and you may try putting the ice cream in a different location.
Jul 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Ice on back wall of freezer, food not staying completely frozen
Do you have the complete model number from the tag on the freezer, it should be either on the bottom rail visible with the door open or on the side wall near the front. I am trying to look this up to see if it is an automatic defrost model, if so you may need to do more than just unthaw and adjust
Thanks
Apr 25, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Food not totally frozen, icecream melted
if it a frost free freezer then chances are it is a defrost hearter, fan motor or defrost timer
if it is not frost free then it will either be the compressor or a gas leak ( which should be under warranty)
Apr 29, 2009 | Frigidaire 16.8 cu. ft. Upright Freezer...
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Kenmore Freezer chest type 14.8 cubic feet
When you open the freezer compartment do you hear a fan blowing? If no the take off the back cover and replace the fan. The compressor has to be on at the same time for the fan to work. If you know what I mean. let me know what happened. thanks.
Nov 24, 2008 | Freezers
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
160 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
