Question about Canon ZR100 Mini DV Digital Camcorder
After having dropped my ( 10 inch drop) camera, I am getting gray vertical bars on my playback. I know it's not a low-light issue or a dirty head issue, because the playback was perfect just before the drop. Anything I can do, short of taking it in for repair?
    Genius:
  • 1,812 Answers
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 03, 2010
How do I eliminate droput of audio/video upon playback?
If it is an old tape which has been used before, there may be creases caused where the pinch wheel pressed against the roller. Try again with a brand new tape. If this is not the issue, he a service is called for.
Jun 17, 2017 | Sony Handycam DCR-TRV310 Digital Camcorder
In playback mode, the video has gray bars running horizontally across the video. Is this a dirty head issue, and if so, what's the solution?
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. Please contact me either by email rjriggins11@yahoo.com or by phone 503-819-3502.
Aug 18, 2010 | Canon ZR90 Mini DV Digital Camcorder
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Gray horizontal lines in playback mode
Gray horizontal lines across the screen in playback is symptom of dirty / clogged video head and you need to use good quality mini-dv video head cleaning tape to clean video head.
Mar 16, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Gray bars on screen during video playback
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Nov 22, 2008 | Sony Handycam DCR-TRV17 Mini DV Digital...
Playback problem
I've encountered this exact problem a month ago, except cleaning the heads did not fix it. However, I was able to find an alternative solution...
After leaving my camera closed up in a drawer for a few weeks, I decided to take it out and leave it in the sun for 15 minutes, assuming that perhaps the gray bars were a result of moisture damage. The next day (Today, to be exact) I turned my camcorder on, and the gray bars have gone away from playback, as well as the reduced sound quallity it caused.
Apr 20, 2008 | Canon ZR800 Mini DV Digital Camcorder
Gray Bars across playback
when you see gray bars that means that your drum is dirty use a soft head cleaning tape for 20 secs and with the posts they are visible by removing the cassette cover there is one for audio it looks like a minus sign on the post and the other is for video and it has a plus sign on top you would need to use a phillips head screw driver with the middle cut out or a pair of twezzers and when you adjust it you turn it a very very little bit to the right start with the one with the minus sign and when the problem goes away when viewing you turn it back just a hair. when you look at the posts you will see in the middle that there is a raised spot that why you would need the tool that i described.
Dec 30, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
Auidio drops
while your monitoring the sound when recording it cuts out or while you playback the tape it dropps out? if it's noticed during playback it's one 3 things. the heads are dirty, the tape tension is low or the heads are bad. send it to video tech service in sacramento. that guy is super cool.
Jun 20, 2007 | Sony Handycam DCR-TRV900 Mini DV Digital...
Canon ZR100 Mini DV Digital Camcorder Logo
66 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
