I can,t keep it running. I don't have instructions. do you have start up instructions. It shuts off after a few minutes.
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Oct 03, 2010
Furnace starts and ignites and fan comes on but when thermostat is turned off the gas shuts off and flame off but furnace continues to run. whu?? any suggestions?
The fan normally runs for a few minutes or so after the gas shuts off.
This removes the heat from the furnace and transfers it into the living space instead of just letting it possibly cause overheating of the furnace until it dissipates. If it is a fan that blows outside, that fan also needs to run for a few minutes to clear exhaust gasses from the furnace - to keep them from dissipating into your home.
Sep 28, 2015 | Heating & Cooling
My dryer starts, runs a few minutes, doesn't heat up and shuts itself off
check your sensors on the heater unit, there are two or more, simply us a meter and make sure power is on both sides of the sensor, if not then that specific sensor is bad and you should replace it, pull the sensor and tie the two wire together to see if it will heat, if it does replace the sensor they are cheap and will keep you from burning down the house
Dec 31, 2012 | GE DWSR463EGWW Electric Dryer
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
Problem keeping engine running on Husqvarna 22HP VT riding mower
Take the fuel bowl off and clean it real good as well clean the fuel jet. It may be the bolt that holds the fuel bowl on. I am not sure. I use my air compressor to blow it out also get a real fine wire and put through the fine hole may help. It does not take very much dirt to make an engine not run right. I repair a lot that way that is not running properly.
Jun 06, 2017 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
Oct 27, 2009 | E-Machines eMachines Desktop PC
1995 Ford Thuderbird
Depending on which type of carburetta this car has, it may be that the rubber diaphram has a tiny pinprick of a hole in it. This will affect the vacumn and the fuel control. An easy way to test this is to allow the car to rest without the engine running for a few minutes, start the engine an increase the power whilst at a standstill and see how long it takes before the engine shuts down, then let it rest again for a few minutes, start the engine and let it run just on tick over, if it carries on running for a much longer period than before then you may have the answer.
Hope this helps Bomber667
Dec 01, 2008 | 2006 Ford Thunderbird
150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
check for proper pump pressure. Restricted fuel flow. Proper venting of fuel cap.
Feb 19, 2008 | Dayton E52 Utility Heater
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
