Question about Dell Inspiron 1525 Notebook
How do i reseat my hard drive, Dell insperon bought in May 2010in Australia. and how can it move if its never been dropped or bumped
  • Jim Winger Oct 03, 2010
    It should not need reseated. What is your problem??
    Master:
  • 397 Answers
You'll need a small-head phillip's screwdriver. Power down the system, remove the battery and the power cord. Hold power button down for 10 secs to discharge any remaining power. Alright, close the laptop lid, place laptop upside down.
On the side with the headphone jack, media reader, and usb ports- you'll see two screwholes- those are for your hard drive. remove them, and CAREFULLY slide the drive out- you'll feel a slight click to it. CAREFULLY slide the drive back in until the plastics are flush- reinsert the screws, and reinsert the battery, power- fire up. Should be good to go! The reason it could require a reseat is the drive uses a pin to cartridge adapter- if that has shifted, then it could cause some problems. Other than that- it should stable, esp. if the screws are in place.
Posted on Oct 03, 2010
Computer will not boot, instead get unmountable boot volume and unsuccessful self fix by computer. How do I best salvage files and programs on hard drive I will be replacing?
You can send the hard drive in and have the files extracted from the drive disc(s) but it is very expensive. Many website offer the recovery service for failed drives.
May 02, 2017 | Dell Computers & Internet
How to reconnect harddrive
To reseat the hard drive on a Dell and it depends upon the model.
Most Dell hard drives are in a slot located behind a panel on the side of the laptop near the audio connectors. The hard drive panel/hard drive tray may be held in place with one or two screws. Remove the screw/s then open the laptop lid and pull/slide out the hard drive panel out. The hard drive panel has the drive tray and hard drive is attached to this panel.
Reverse this order to insert/reseat the hard drive back into your laptop.
May 14, 2012 | Dell Computers & Internet
I bought a used Vostro service tag 4L9NLF1 with no hard drive. i installed my own hard drive but the machine is asking for a password even to enter bios.
Hi!!!
You can delete the bios password by reseating the coin cell battery of your computer. To do that please click this link for procedure on how to do it.
Dell Vostro 1500
Thanks!
Mike
Jul 14, 2011 | Dell Vostro 1500 Notebook
I have just bought a toshiba satellite p750 pc.Whenever my laptop moves I get the following message: Vibration has been detected in the PC the hard disk drive head is temporarily moved to a safe...
Your laptop has a feature/utility that turns off the hard drive when bumped to something or move. This feature is to protect the hard drive from data corruption and hard drive failure. It is like a shock sensor. Check for the software of that feature and see if you can decrease the sensitivity.
Hope this helps.
Jun 20, 2011 | Toshiba Portege R500-S5004 Notebook
Missing hard drive
1) Try to reseat the hard drive. Remove the Battery and the power adapter first. Follow the steps on removing the hard drive form here http://support.dell.com/support/edocs/systems/ins1525/en/SM/hdd.htm#wp1180023
place it back again. and turn it back on.
2) if it still does not work the best thing to do is to contact dell tech support for hard drive troubleshooting. they may require it to be sent to them specially if it is still within warranty.
Apr 28, 2010 | Dell Inspiron 1525 Notebook
I want to add a second hard drive (SATA) to a Dell insperon 530. Where does it connect to the motherboard?
Every SATA enabled motherboard has atleast 2 SATA ports. Trace the first SATA cable and you'll find another port closer. If your Optical drive is connected to it, and if you can find an IDE port on your motherboard, buy an IDE to SATA convertor and plug it in.
Apr 10, 2010 | Dell Inspiron 530 Desktop Computer
Two beeps ptimary drive primary drive not found
While hard drives do die the usual suspect is a loose cable. All it takes is a bump or it running hot and the cable can become loose. You need to open the case and then reseat the conenctors. (Just pull one end off then put it right back on. )
You can replace the drive fairly cheaply but will need to reinstall windows and your software etc.
Mar 23, 2010 | Dell OptiPlex 270 PC Desktop
I recently moved and when i went to start up my computer it takes me to a blue screen say memory is being dumped. Prior to that though there is a screen saying that a "0 drive" can not be found. Any idea...
Your 0 Drive is the main hard disk drive in your computer. That is where Windows is installed. If the pc doesn't see it, it cannot start. If you've moved, the hard drive cable or power connection may have come loose. You can try opening the case and reseating all connections and see if that works. If not, it's possible your hard drive is damaged and not working.
Feb 19, 2010 | Dell Dimension 4600 PC Desktop
Dell Inspiron 1525 Notebook Logo
793 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
