Question about Gaggia Carezza Espresso Machine
My Gaggia Carezza espresso machine suddenly stopped working. When I flip the power switch on the machine, the light doesn't come on, and there are no signs of life whatsoever. I took it apart and I didn't find any loose connections. Bad switch?
  • doug144 Sep 24, 2013
    The switch was melted, fused open. For the Carezza, this is a strange bipolar switch with a replacement cost of $40.
    President:
  • 1,618 Answers
Check the thermostats
Posted on Oct 04, 2010
Replacement for Gaggia Carezza ON switch?
It is a standard switch, so you can repalce it, as long as you know what you are doing
Aug 19, 2012 | Gaggia Carezza Espresso Machine
'on' switch on Gaggia Carezza not working
Usually it is the switch itself that has failed. Order the switch from your appliance repair/supply business and replace the item in the machine. A lot of these switches have plastic 'ears' that need to be pressed in to release the old part and the wire connections are usually 'push-on'. Some that are held on by a formed metal clip usually require breakage of the clip to release the part and the new switch should have a replacement clip. Hope this helps!
Feb 14, 2010 | Gaggia Carezza Espresso Machine
I have a Gaggia Carezza machine that is about 3 years old. Yesterday, the power switch seemed to have some resistance when I turned it off. I also smelled a burning plastic smell. Today, the switch seemed...
The description sounds like the switch has failed due to it's internal contacts arcing. I have a like problem with Mary214 that is ongoing. Please follow that thread to find your fix.
Dec 27, 2009 | Gaggia Carezza Espresso Machine
Cannot find replacement for the Gaggia Carezza powerswitch anywhere. Model discontinued. Want to jump the wires so that it is on when I plug it in.
Here is a list of gaggia dealers, one of them might have it, if not check with radioshak.
I do not have it so you can skip me.
Oct 09, 2009 | Gaggia Carezza Espresso Machine
Doesn't produce steam for more than 1 minute.
You should not have your steam wand on for more than a minute.
Jun 29, 2009 | Gaggia Carezza Espresso Machine
Gaggia Carezza will not turn on
look on top of the boiler you will find a microthermo  it trips when the machine gets too hot and you are going to have the replace it. now i posted the fix in a form for the same thing. and where to get one.
Apr 20, 2009 | Gaggia Carezza Espresso Machine
Gaggia Carezza Espresso Machine burned out
as i understand from your decriptition, you had temperatire rising in extreme point. termofuse should worked but it didnt, i advice you to change all 3 and some seals:
  1. Thermofuse
  2. Thermostat water L=107C
  3. Thermostat steam L=145C
  4. Gaggia gasket 6-pc. Kit (during changing them you can clean boiler too)
here is the link for diagram:
http://www.partsguru.com/user/Carezza%20diagram%20and%20parts%20list.pdf
here is the link for parts:
http://www.partsguru.com/GaggiaCarezzaespresso.html
Apr 03, 2009 | Gaggia Carezza Espresso Machine
Gaggia Carezza not turning on
I just bought a broken Carezza for my office (and hacking)-- the owner said the power switch only worked when he held it down hard.
Taking it apart, the main power switch-- a DPDT automotive-style unit-- is broken on one pole-- the wire connectors are slightly melted and darkened, and the switch has melted, discolored plastic around the metal tabs.
A new switch should bring it back to life, and I'll install a removable power cord and 15A fuse for niceness/safety-- the switch is rated for 20A at 125VAC so shouldn't have fried.
Feb 16, 2008 | Gaggia Carezza Espresso Machine
Gaggia Carezza doesn't brew
May need priming -- follow the directions in the manual.
Jul 01, 2007 | Gaggia Carezza Espresso Machine
Gaggia Carezza Espresso Machine Logo
173 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
