Question about Mr Gasket Timing Cover Chevrolet El Camino Elcamino 75
How do you set the timing chain for a 2000 cavalier?
  • Chevrolet Master
  • 6,826 Answers
Timing Chain and Gears REMOVAL & INSTALLATION 2.2L Engine Fig. 1: The timing marks on the sprockets should be in alignment. If not, turn the crankshaft until the marks are aligned how do you set the timing chain for a 2000 - 91113p63.jpg
Fig. 2: The timing chain tensioner is retained by a Torx head bolt (1) and a regular hex head bolt (2) 91113p58.jpg
Fig. 3: Unfasten thhow do you set the timing chain for a 2000 - 91113p59.jpgprocket bolt 91113p59.jpg
Fig. 4: Remhow do you set the timing chain for a 2000 - 91113p60.jpghaft sprocket and the timing chain at the same time . . .
Fig. 5: . . . then remove the tensioner assembly 91113p61.jpg
Fig. 6: Compress the tensioner spring and insert a cotter pin or nail in the hole provided to hold the tensioner in position 91113p62.jpg
  1. Disconnect the negative battery cable.
  2. Remove the front cover as previously detailed.
  3. Place the No. 1 piston at TDC of the compression stroke so that the marks on the camshaft and crankshaft sprockets are in alignment (see illustration).
  4. Loosen the timing chain tensioner nut as far as possible without actually removing it.
  5. Remove the camshaft sprocket bolts and remove the sprocket and chain together. If the sprocket does not slide from the camshaft easily, a light blow with a soft mallet at the lower edge of the sprocket will dislodge it.
  6. Using a suitable gear puller, remove the crankshaft sprocket. To install:
  7. Press the crankshaft sprocket back onto the crankshaft.
  8. Install the timing chain over the camshaft sprocket and then around the crankshaft sprocket. Make sure that the marks on the two sprockets are in alignment (see illustration). Lubricate the thrust surface with Molykote® or its equivalent.
  9. Align the dowel in the camshaft with the dowel hole in the sprocket and then install the sprocket onto the camshaft. Use the mounting bolts to draw the sprocket onto the camshaft and then tighten to 66-68 ft. lbs. (91-95 Nm).
  10. Lubricate the timing chain with clean engine oil. Tighten the chain tensioner.
  11. Installation of the remaining componhow do you set the timing chain for a 2000 - 87953107.gifhe reverse order of removal. Fig. 7: Exploded view of the timing chain and sprockets - 2.2L OHV engine 87953107how do you set the timing chain for a 2000 - next.gifass=
Posted on Oct 12, 2010
  • Duane Wong
    Duane Wong Oct 12, 2010
    2.3L and 2.4L Engines
    Before attempting to remove the timing chain, read the entire procedure.
    2. Remove the timing chain front cover, as outlined earlier in this section.
    3. Rotate the crankshaft clockwise, as viewed from the front of engine/normal rotation, until the camshaft sprocket timing dowel pin holes line up with the holes in the timing chain housing. The crankshaft sprocket keyway should point upwards and line up with the centerline of the cylinder bores. This is the "timed'' position.
      Fig. 8: The chain must be in the "timed'' position - 2.3L and 2.4L engines
      Fig. 9: Remove the timing chain guides
    4. Remove the timing chain guides.
    5. Raise and safely support the vehicle.
    6. Make sure all of the slack in the timing chain is above the tensioner assembly, then remove the tensioner. The timing chain must be disengaged from any wear grooves in the tensioner shoe in order to remove the shoe. Slide a suitable prytool under the timing chain while pulling the shoe outward.
      WARNING
      Do NOT attempt to pry the socket off the camshaft or damage to the sprocket or chain housing could occur.
    7. If difficulty is encountered in removing the chain tensioner shoe, remove the intake camshaft sprocket, as follows;
      1. Carefully lower the vehicle.
      2. Hold the intake camshaft sprocket with a suitable tool and remove the sprocket bolt and washer.
      3. Remove the washer from the bolt and rethread the bolt back into the camshaft by hand. The bolt provides a surface to push against.
      4. Remove the camshaft sprocket using a three-jaw puller in the three relief holes in the sprocket.
    8. Unfasten the tensioner assembly retaining bolts, then remove the tensioner.
      NOTE: The timing chain and crankshaft sprocket MUST be marked before removal. If the chain or sprocket is installed with the wear pattern in the opposite direction, noise and increased wear may occur.
    9. Mark the crankshaft sprocket and timing chain outer surface for reassembly, then remove the chain.
    10. Clean the old sealant off the bolt with a wire brush. Clean the threaded hole in the camshaft with a round nylon brush. Inspect the parts for wear and replace as necessary. Note that some scoring of the chain shoe and guides is normal.
      To install:
      WARNING
      Failure to follow this procedure may result in severe engine damage.
    11. Position the intake camshaft sprocket onto the camshaft with the surface marked during removal showing.
    12. Install the intake camshaft sprocket retaining bolt and washer, tighten to 52 ft. lbs. (70 Nm) while holding the sprocket with a suitable tool. Use GM sealant 12345493 or equivalent on the camshaft sprocket bolt.
    13. Place GM tool J 36008, or equivalent camshaft aligning pins, through the holes in the camshaft sprockets into the holes in the timing chain housing. This positions the cams for correct timing.
    14. If the camshafts are out of position and must be rotated more than 18 turn in order to install the alignment dowel pins, proceed as follows:
      1. The crankshaft MUST be rotate 90°clockwise off of TDC in order to five the valves adequate clearance to open.
      2. Once the camshafts are in position and the dowels installed, rotate the crankshaft counter clockwise back to TDC.
        WARNING
        Do not rotate the crankshaft clockwise to TDC; valve or piston damage could result.
        NOTE: The side of the timing chain that was marked during removal must be showing when the chain is installed.
    15. Place the timing chain over the exhaust camshaft sprockets, around the idler sprocket and around the camshaft sprocket.
    16. Set the camshafts at the timed position and install the timing chain. Remove the alignment dowel pin from the intake camshaft. Using GM tool J 39579, rotate the intake camshaft sprocket counter clockwise enough to slide the timing chain over the intake camshaft sprocket. Release the camshaft sprocket wrench (J 39579 or equivalent). The length of the chain between the two camshaft sprockets will tighten. If properly timed, the intake camshaft alignment dowel pin should slide in easily. If the dowel pin does not fully index, the camshafts are NOT timed correctly and the procedure must be repeated.
    17. Leave the alignment dowel pins installed. Raise and safely support the vehicle.
    18. With the slack removed from the chain between the intake camshaft sprocket and the crankshaft sprocket, the timing marks on the crankshaft and cylinder block should be aligned. If the marks are not aligned, move the chain one tooth forward or rearward, remove the slack and recheck the marks.
      Fig. 10: Timing chain assembly retaining bolts - 2.3L and 2.4L engines
    19. Reload the timing chain tensioner assembly to its "zero'' position as follows:
      1. Form a keeper from a piece of heavy gauge wire, as shown in the accompanying figure.
      2. Apply slight force on the tensioner blade to compress the plunger.
      3. Insert a small prytool into the reset access hole, and pry the ratchet pawl away from the ratchet teeth while forcing the plunger completely in the hole.
      4. Install the keeper between the access hole and the blade.
        Fig. 11: Reloading the tensioner to its "ZERO'' position, then install to the chain housing
    20. Install the tensioner assembly to the timing chain housing. Recheck the plunger assembly installation, it is correctly installed when the long end is toward the crankshaft. Install the tensioner retaining bolts; tighten to 89 inch lbs. (10 Nm).
    21. Carefully lower the vehicle enough to reach and remove the alignment dowel pins.
      WARNING
      Severe engine damage could result if the engine is not properly timed.
    22. Rotate the crankshaft clockwise (normal rotation) two full rotations. Align the crankshaft keyway with the mark on the cylinder block and reinstall the alignment dowel pins. The pins will slide in easily if the engine is correctly timed.
    23. Install the timing chain guides, then install the front (timing chain) cover.
    24. Connect the negative battery cable.
    Previous Next
Set timing on 2000 chevy 2.2L
I looked at info 2000 cavalier 2.2L engine. This is for timing chain. Ignition timing is not adjustable.
Make sure you clean those sprockets very good so you can be sure of timing marks?
You don't want to accidently time it off a dirty spot, btdt. lol
Mar 31, 2018 | Chevrolet Cars & Trucks
Timing chain and sprockets replaced but the car will not start on a 2003 chevy cavalier 2.2l
I had a 2000 cavalier with a 2.2L single cam and there is a timing arrow on the crankshaft sprocket and there is one on the cam the crank sprocket mark should point up toward the cam and the cam mark should point str8 up also so 12 o'clock and 12 o'clock
Dec 07, 2011 | 2003 Chevrolet Cavalier
How to replace a timing chain 1999 chevrolet cavalier
This engine uses a timing chain not a belt, the 2.2 liter uses a blet, a chain has no set tikme to change, they las the life of the engine.
May 27, 2010 | 1999 Chevrolet Cavalier
2oo2 cavalier timing chain broke need to know how to fix it??
With a new motor most likley. When a timing chains break pistons tend to collide with valves which can punch holes in the pistons or bend/ break valves. Usually at this point it is more economical to replace the engine than to actually fix it.
Jan 20, 2010 | 2000 Chevrolet Cavalier
I need to place timing chain on 1996 Chevrolet Cavalier. I need to know estimate of cost?
All shops charge differently. Call around. Plan on spending about 500 give or take.
Jan 12, 2010 | 1996 Chevrolet Cavalier
Timing chain noise 2005 cavalier 2.2 ecotec
Just the guide is probably making the noise. So either a new guide or a new chain. I would start with guide first, unless chain looks loose or cruddy
Sep 16, 2009 | 2005 Chevrolet Cavalier
How to change the timing chain of 2000 cavalier 2.4 engine twincam?
I suggest that you visit the autozone.com website and register the car. It doesn't cost anything and you will have access to an online repair manual for the car. The info on the timing chain should be available there. It's a handy resource. Hope this helped and best wishes.
Sep 09, 2009 | 2000 Chevrolet Cavalier
I just bought a 2000 Cavalier z24 2.4L, when i test drove it nothing appeared but when i start it after it has been running it makes a clicking noise like a fast rattle under the hood, but when i step on...
tming chain tensioner problem,the guide wears off over time ,there is an aftermarket updated part for this,but the whole timing cover and chain assembly has to come apart
Sep 05, 2009 | 2000 Chevrolet Cavalier
Ticking on top of engine near timing chain side.
this is usually a bad timing chain tensioner yo can change this without removing chain jst have to tear down far enough to remove cover
Aug 17, 2009 | 2000 Chevrolet Cavalier
How to replace a timing chain 2000 chevy cavalier
I am familiar with that vehicle but generally with timing chain replacement, the engine needs full access for pulley and cover removal and in some cases the cylinder head requires removal.
Generally timing chains last so that they only need replacement at engine overhaul and it is not an economic proposition to have to replace a chain unless some relative degree of engine work is also required at that time.
Engine timing chains generally have a tensioner on them which maintains tension, but some chains can wear significantly and cause timing cover to be "ground away" because of "slop".
If the engine is making the noisy rattle of the timing chain against the cover etc, I would schedule a top overhaul (head, machine, test and valve grind) with the chain replacement dependent on mileage with the degree of action.
Some simple simplex timing chains (type of chain similar to motor bike chain) may be replaced without dismantling the engines but I would expect your chain would be a "duplex" dual sprocket type, these are most common.
These chains are not generally expensive but replacing them can involve a fair amount of work.
Good Luck and hope this helps, Others will have different ideas.
May 04, 2009 | 2000 Chevrolet Cavalier
Mr Gasket Timing Cover Chevrolet El Camino Elcamino 75 Logo
1,269 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
