Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
My freezer is frosting up and a layer of frost is covering everything that is in it..... I suspect gasket needs to be replaced... a visual check of it seems to indicate the bottom corner may not be a tight fit...
    Sergeant:
    Champion:
  • 351 Answers
Yes that could be it or door isn't closing right there air getting there some where
Posted on Oct 03, 2010
Frigidaire frost free upright freezer door corner dripping
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
Sep 01, 2015 | Frigidaire 13.7 cu. ft. / 388 liter...
We have a Gallery model refrigerator/freezer. I opened the freezer this morning and everything was covered with excessive frost.
Thank you for your post, friend!
I see that you are receiving an excessive frost buildup on the inside of your Frigidaire refrigerator. I would check the gasket to very it is sealing properly. You can do that by using a dollar bill. Place the bill between the body of the fresh food and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet then the gasket may need to be replaced. I hope this information has been beneficial. - Matt
Oct 11, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Hotpoint hss251fmd and the freezer and refrigerator are getting warm at the top. the bottom and the back are cold. The freezer Is cold but not freezing everything. There's alot of frost inside...
Sounds like defrost cycle has been altered. Look into back of freezer and see if a layer of frost is building. If yes then unplug and place items from freezer into an ice chest or another freezer. Remove the panel that showed the frost layer and defrost the evaporator coils with a hair drier Examine the WR51X10055 Defrost Heater and test if you cannot see burn marks HERE It does not hurt to also change the WR50X10068 Defrost Thermostat Instructions on replacing the defrost thermostat are also on the same page. Here is a=> Service Manual
I will be here to answer any questions, Thanks Sea Breeze
May 08, 2012 | GE Refrigerators
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
The refigerator and the freezer is not cooling
Check your door gasket seals - make sure your condenser is not dirty and covered with dust.
Check your thermostat setting, raise the knob if applicable.
One thing to check too is at the back of your freezer's panel, look for any over frosting evap coils and a malfunctioning evap fan - an over frosted evap will cause poor cooling.
You can diagnose this yourself by defrosting manually with a blow dryer - if cool returns that was your problem - in which case you will need to replace the control board and check the defrost timer components !
Sep 26, 2009 | Kenmore Refrigerators
Just defrosted my freezer and is akll frosted over
When you say it is frosted over, do you mean the interior of the freezer is frosted, or the evaporator coils?
A couple things to check for:
1. Is the door gasket making a good seal when you close the door? A good quick fix for a bad seal on the gasket is to rub a thin layer of Vaseline (the original jelly kind works best) on the rubber to help it stick and to fill any scratches that might be keeping it from sealing tightly.
2. Is the fan running on the inside of the freezer? The evaporator coil in the freezer needs a fan to blow air over the coils to keep them from freezing over. They don't run continuously, and on some units will turn off when the door is open, so try holding the door switch shut when you check.
3. Is the defrost cycle working? Frost-free freezers have a defrost cycle in which a small heater turns on to thaw any frost that has begun to form. To check the functionality of the heater and the defrost timer will probably require a visit from a technician... It would take a while to explain it here, but if check the first two and come up empty handed, post back. You will need a volt/ohm meter.
I would check the first two
Mar 24, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
MAYTAG MBB1952HEW - Bottom-Mount
I have this exact problem...was there a solution? Frost is causing bottom freezer door not to work, when I remove the frost, the light comes on. The gasket looks fine. Any Ideas?
Aug 14, 2008 | Maytag MBF2556HEW / MBF2556HEB /...
Layer of frost on the bottom surface of ice maker
during periods of high humidity and or high use, it is not unusual to notice frost on surfaces in the freezer. the ICM is susceptible due to it being metal and having warm(compared to freezer temp) water in it. make sure the doors ar closed tight and nothing is stuck in the gasket area.
J
Jun 13, 2008 | GE Profile PSI23NCR Side by Side...
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
103 people viewed this question
Top Viking Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
