Fischer & Paykel Excellence 6.5 1999 model Neclace has gone through wash and drain holes. Making terrible grinding noise. need instructions how to take off cover to find neclace.
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.Now try this.Select a spin cycle and push the start button.Do you hear the noise straight away after the button is pushed or do you hear the noise later when the machine is starting to turn the bowl?The reason I ask you this is because as soon as you push the start button the drain pump will activate and then a couple of minutes later the bowl will start to turn.So if the noise starts straight away then the necklace is in your pump and if the noise starts later it is stuck to the bowl.Please reply with the additional information and I will guide you throe the removal of the necklace.Looking forward to your reply.
Posted on Oct 03, 2010
  • ajandcat Oct 04, 2010
    Thank you for the reply. There is no sound when the spin cycle starts up so it must not have got to the pump. the sound begins when the bowl starts to turn.
Fisher & Paykel Washing Machine
Check out the fuses on the main controller board if they are fitted. If you need a new motherborad you can get one from Fisher & Paykel in Australia at http://www.fisherpaykel.com.au/customercare/contactus/
Sep 08, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
F & P Smartdrive Excellence works fine until it reaches the rinse and then just makes whirring noise. I can't get it to spin either and it won't empty. Is there a way of at least draining it. Cheers...
Hi Kiri,
F&P mahcines are a little hard to drain as the drain hose comes out of the rear of the cabinet half way up.
You may have to use a small container and manually bucket it out.
The drain pump is more than likely blocked (seen this a lot on the F&P) and is accessable from the front panel or underneath the machine.
Repost if you need anymoe help!
Jun 17, 2009 | Fisher and Paykel Fisher & Paykel Washer
Maytag Washer model #PAV2360AWW
It is not the trany it sounds like you need to get your tub seal and bearing kit installed.The trany is fine it can get costly if you get a person who does not know how to fix properly good luck:)
May 04, 2009 | Maytag PAV2300 Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Grinding Noise
Wash out the drain and filter.
May 08, 2008 | Amana 24 in. ADB3500AW Built-in Dishwasher
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
