Question about Freestyle Nomad Watches: Nomad Black Watch
Trying to reset new battery on Freestyle Nomad watch, cannot find AC pad?
How to change battery shark 88 freestyle
  • Remove back
  • Locate battery and identify type. Note battery mounting arrangement for later reference
  • Obtain replacement battery
  • Remove old battery and install new
  • Check operation
  • Install back
  • Set time, etc.
Sep 05, 2016 | Freestyle Shark 88 Watches
Timex Rush Indiglo Watch: shorting the AC pad to the battery
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic.
There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.
I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery..
Sep 05, 2012 | Timex Indiglo Watches
My freestyle model 798 is contantly resetting itself back to Jan. 1 12 am. Is this a battery problem?
No, this is not a battery problem. Use your users manual and read how to reset time and date.
Jan 12, 2010 | Freestyle Watches
I have a square Freestyle watch. It keeps beeping, can't trn off
You can try taking the battery out and waiting a minute or two then replace but you should probably have a watch maker/technician "AC" or clear the watch. This involves resetting the circuit board and only takes a moment. I would also have them reseal the watch and pressure test it as Freestyle's are made to be in water and you will want to maintain the water resistance.
Sep 17, 2009 | Freestyle Shark Predator Wrist Watch
I have a Timex Indiglo watch that I had replaced the battery. I used the correct battery CR2016 and the watch doesn't work. I have replaced batteries in watches many times and always have had the watch...
This watch will have what is called and "AC" or All clear to reset it. There should be a white sticker with very small print on the back lid that will walk you through doing this procedure. It typically involves pressing down a tiny lever onto a small metal pad that will reset the watch.
Sep 15, 2009 | Timex Watches
After replacing a battery in a timex ironman with data link, they tell you to short the ac pad and the vss pad. Were are those points located?
You will find them on the module itself.
So after replacing the battery look on the PCB (printed circuit board) for the letters"AC" and "VSS". Adjacent to these markings there should be little contact points (probably gold or silver looking in colour)
Use a paper clip or similar and bridge (short) these two points simultaneously. Please rate my solution.
Jul 26, 2009 | Timex IRONMAN Triathlon Data Link T53722...
Timex rush new battery reset
good morning ! you need to use the pointed twisser to short the two reset pad ! thanks !god bless !...
Sep 02, 2008 | Timex Rush Sports Watch
Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...6e1fe0e.jpg
May 31, 2008 | Timex Advanced Data Link 53722 Wrist Watch
Freestyle Nomad Watches:  Nomad Black Watch Logo
278 people viewed this question
Top Freestyle Watches Experts
ray gallant
Are you a Freestyle Watch Expert? Answer questions, earn points and help others
